Results 1 to 7 of 7
    Active Member Two Rings seannb78's Avatar
    Sep 18 2007
    2013 Audi TT RS, 2013 Mercedes GLK350
    Land O Lakes, FL
    Spacer wheel bolts. How long do I need them to be?
    I just got some H&R spacers for my birthday and I need to know what length bolts I need to use to replace the stock ones.
    I got 8mm for the front and 15 mm for the rears.
    I have stock RS6 18" wheels on S-Line, FWD A4.
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Re: Spacer wheel bolts. How long do I need them to be?
    To determine the correct bolt size, add the width of the spacer to your stock lug bolt size (28mm for OEM applications). I used ecstuning.com for this info.
    so 28mm + 8mm; 28mm + 15mm
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Senior Member Two Rings Widget's Avatar
    May 22 2007
    '06 A4 S-line, 2.0TQMT - Moro
    New England....
    The calc above is perfect to get you in the hunt. Unfortunatly, bolts don't come in exact incremental lengths. Error on the side of caution and get the longer size if you are in the middle. To short is UNSAFE!!!! I ran a set of 40mm bolts from ECS w/ 8mm spacers for a week or so. Just triple check that clearance is ok once everything is on. FWIW I didn't have any clearance issues. If you do, just shorten the bolts.
    Moro Blue Photo Thread
    WTB: | Stasis SS coilovers | 19" Gunmetal RS4 reps PM me...........
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Yeah, I would go probably 1mm over what you need, they'll only hit if they're over 5mm too long or something.
    Make sure you get the correct seat on your lug bolts (conical or ball seat)
    Ignorance is bliss.
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    /\ /\ /\ yeah...what all 3 of them said. if you are in the the middle of the provided bolt length, go the next higher.
    Quote Originally Posted by Phrost View Post
    looks like he's using stock wheels, so make sure you get ball/radius/round seat bolts.
    my usual links on this type of subject:
    http://www.tirerack.com/wheels/tech/...jsp?techid=102
    http://www.tirerack.com/wheels/tech/techpage.jsp?techid=107*
    *btw our bolts are 14 x 1.5 mm (diameter x thread cut) <--not length measurement.
    Sep 24 2010
    Irvine, CA
    This post was in 2008. I found it when I searched for wheel bolt length suggestions toward spacers.
    My car is 2005.5 S4. Stock wheels.
    Questions:
    1. I bought H&R 24mm spacers for the rear. I suppose the wheel bolt length needed is 28+24=52mm min.? Would 50mm be OK?
    2. What is the suggestion for the spacer thickness for the front to best fit the 24mm spacers in the rear?
    3. Do I need to do the alignment after putting on the spacers?
    Quote Originally Posted by LAS View Post
    Veteran Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    B7 RS4
    Québec
    Quote Originally Posted by darrenho View Post
    Questions:
    Answers:
    1) Stick with 52 MM. Safety First. It is better to go a bit more than under.
    2) I don`t know, I run even 10MM spacers back and front. From what I read, people running 12MM Front, 15MM Rear. Should give you a Idea. SEARCH !
    3) No alignment needed.
    B7 RS4
