Originally Posted by
Obi_agent
Nice launch
More specs on your and Z06,please:)
Unfortunately I don't know anything else about the Z06 other than that it's an '08 with a procharger on meth injection.
Here are some specs on my car:
2000 VAST stage 3+, K04's, VAST software, hi-flow fuel pump, green giant injectors, Ported and polished exhaust manifolds, piggie pipes, RS4 Airbox, MAF, and accordion, VAST stage 3 ceramic organic hybrid clutch and RS4 PP, poly snub, RS4 motor and trans mounts, innovate wideband AFR gauge, low temp after-run switch, Bailey sport DV's, Milltek 3" exhaust-rear muffler delete, neuspeed rear sway bar, Eibach sport pro, Bilstein sport, E-code 55W HID, Enkei RPM2's w/ 235/40/18 Kumho Ecsta SPT, RS4 intercoolers, RS4 front bumper and grill, Custom backlit bird's eye maple shifter with JHM solid short shift and delrin bushings and rebuilt shifter linkage, JHM rebuilt and upgraded tranny, AWE DTS, PureMS poly rear-diff mounts and power ring center-diff mount, clutch fan delete, N249 delete.
