Results 1 to 6 of 6
    Registered Member Two Rings sprintblues4's Avatar
    Jul 29 2007
    B7 S4
    Bensalem, PA
    Want to paint rear valance flat black?
    Has anyone painted there own factory rear valance with good results? I changed my front grill with the RS4 grill with flat black filler plate and want to carry the same theme in the rear. I really don't feel like paying a shop to paint it if I can do it myself with good results. I was thinking of using Krylon spray paint or something along those lines. Will I need to prime it or just prep it and paint. I figured if it comes out bad I'll just have to buy a CF valance or pick up a used one. Any advice or suggestions would be great. Thanks.
    Full Milltek system non res., Vogtland coilovers, H-sport RS4 29mm rear, Huper Optik nano-ceramic tint, 19" OZ Superleggeras, RS4 grill
    Jul 29 2007
    B7 S4
    Bensalem, PA
    Re: Want to paint rear valance flat black?
    Anyone?
    Established Member Two Rings vovpar's Avatar
    Nov 30 2007
    04 S4
    Sacramento, CA
    i have a B6 if its any help that painted flat black.
    I prepped it, sprayed with special high temp sticky primer and painted it using bumper coater flat black with high temp resistance
    Take a look...........hope it helps!
    04 S4 6Speed DOLPHIN GREY~iForged~APR~REMUS~Sebring~
    Veteran Member Three Rings nealRlett's Avatar
    Nov 27 2007
    B7 S4, '71 BMW R75/5
    I painted mine. Matched it to the front 'satin-black' filler plate. Had the shop paint it. I agree with your decision; If you change the grill, you have to match it to the rear valence.
    Jul 29 2007
    B7 S4
    Bensalem, PA
    Thanks guys. That's exactly what I want to do. So I need to use a high temp paint and primer? Do you know the brands and where I can buy them.
    Active Member Two Rings ForthRightAfter's Avatar
    Jan 09 2008
    04' S4 Sedan
    Hempstead, NY
    I Actually just got a whole new paint job on my b6 S4 Dolphin Gray and painted the reat valance to match the paint. ill display pictures tomorrow when i get my car
