Results 1 to 2 of 2
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Another coolant leak issue!
    Parked my car today after a spirited run ( GT28 A4) and i noticed that coolant was leaking in the area of the oil drain nut so naturally i look above that and its all dry. It doesnt make sense to me. Anyone have any ideas as to where to coolant might be leaking from? Coolant return line for the turbo is dry as well. The only thing coolant related that i touched this evening was my coolant temp sensor(I replaced it) and then refilled the coolant because i lost some coolant when i pulled it out.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Apr 16 2007
    Queens
    Re: Another coolant leak issue!
    Im thinking maybe some condensation from the engine and some of the residual coolant that spilled earlier in the day is really what im seeing because I took the car out again for a drive
    and its not "leaking" anymore.
    2003 A4 1.8TQM
