Results 1 to 8 of 8
    Senior Member Three Rings audihtp's Avatar
    Sep 28 2007
    Levittown, NY
    what dealer do on 105000mile service?
    just wondering since I got the letter from dealer, what they do on those.
    just regular fluid change and tune up?
    Active Member One Ring katcoota's Avatar
    Apr 27 2008
    Audi S6 MT6 2001
    UK
    Re: what dealer do on 105000mile service?
    If you've gone this far and you haven't had your timing belt done, yikes, you need it done asap. Any dealer should be able to do this.
    However, the Timing Belt (TB) is going to make this service at the dealer a killer. I would suggest you find a local specialist or Indy VAG place to do this for you.
    Read up in the forum on TB changing. Make sure the full thing is done including all rollers, tensioners, waterpump and thermostat.
    You can find the kits at ecstuning or blauparts, and an Indy should be able to save you a few thousands off the dealer's price.
    Sep 28 2007
    Levittown, NY
    Quote Originally Posted by katcoota View Post
    Well Timing belt is done soon as I bought audi it went for timingbelt. it was 1300+ at dealer.
    so just wondering whatelse they do. do they do trans fluid and filter change?
    Apr 27 2008
    Audi S6 MT6 2001
    UK
    Have a look at this link. It lists what should be done at the various service intervals.
    http://www.bentleypublishers.com/tech/audi
    This doesn't mean that the Audi dealership will do all of the items listed. So you should check with the one you want to use directly.
    Sep 28 2007
    Levittown, NY
    katcoota, thanks for the link. I'm gonna go through and check what I need and maybe get a quote on it.
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    Don't go to dealer for this -- it will be at least 2x the cost of what it should be.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Sep 28 2007
    Levittown, NY
    Quote Originally Posted by skiroad'r View Post
    true.
    will lookin into some independent guys around long island.
    Apr 21 2008
    Central New Jersey
    Try this guy, highly, highly recommended
    http://elitemotorsports.org/index.html
