Results 1 to 7 of 7
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    programming transmitter key
    OK, WHAT do I need to do to get results with the search on AZ??? I have a transmitter key and I need to somehow program it/get it cut.
    *Do you HAVE to go to the Stealership to get the key cut?
    *How do you program this thing?
    I tried searching for "transmitter key" "program transmitter key" "program keyless entry" + more, I keep getting ) RESULTS MATCH
    If someone would point me in the right direction, I'd be forever greatful.\
    thanks,
    -Kyle
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: programming transmitter key
    Try key fob
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I believe a write up is over on Audiworld. You can get it cut for cheaper at a VW dealer
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Dec 05 2007
    http://audizine.com/forum/showthread.php?t=71439
    As for getting the key cut, the stealership can do that. With the design of the key, I am not too sure if other places such as True Value can cut it for you. But is def worth a try. Save some bucks.
    I remeber coming across a different write up though. Where no vag come was needed.<<<not too posotive though
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Isn't it a thing where you unlock the driver door manually and like press the buttons when its in the lock? I remember I programmed my B5 like that. I forgot the exact process though
    Village Idiot!!!
    (\__/)
    (")_(")
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Yes you can program it with one remote, but you have to have two keys. I only had one initially, so I bought my remote and key off ebay. Then took the key to the dealer to be cut. He asked if I wanted it programmed and I said no. Now once you have two keys follow these instructions:
    1. Take your first key and insert it into the ignition. Turn it one click forward.
    2. Roll down your window just in case. Step outside the car, and lock the car with the second key.
    2b (optional, it might take a few times). Take key out of lock (it wouldn't program with the key in the lock for some reason)
    3. With your key remote press the unlock button. The lights (my brake lights) should flash.
    4. Now lock the car with the remote, and then unlock it. (it should unlock your doors).
    5. Remove the key from the lock and the key from the ignition, and try it's function.
    I couldn't get an uncut key, so I bought a a6 remote with a cut key ($15) and then just a blank blade ($20)
    (the dealer cut it for $10 bucks), and followed these instructions to swap blades:
    Swapping keyblades…
    The keyblade is held in place with a small roll pin, flip out the keyblade halfway and you'll see it.
    To separate the keyblade from the device, just hammer out the pin with an appropriately sized punch or nail.
    After that, you should be able to pull the keyblade away from the device.
    If you can remove the keyblade properly, you can figure out how to reinstall it onto a new remote on your own.
    When reinstalling, just make sure the side of the keyblade with the logo “Huf” is facing the opposite side of the
    panic button when flipped outward, or else the roll pin would not go in
    http://www.audiforums.com/m_4743/tm.htm
    That should work.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Established Member Two Rings Zoidbort's Avatar
    May 20 2008
    Victoria, BC
    I have 3 keys, the valet, carbon emergency, and the newer fob I bought off eBay. I programed the fob to open my doors etc but the cars immobilizer does not recognize the key fob blade and my car shuts off 2 secs after I start it. Do I have to get the stealership to reprogram it ($70) or can I use my VAG to do it? I had previously read that you need the original security code that came on the key chain when the car was 1st bought to use the VAG to reprogram it but I am the second owner and do not have that code. Any ideas or suggestions?
