Results 1 to 13 of 13
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    oil consumption problem
    ive been having a serious problem with the amount of oil that has been being consumed with my b6 s4. it seems to be that every 320 miles i drive my low oil light has come on and they have checked sensors under the car puled the spark plugs and everything looking for where this oil might have gone but so far they cant find anything wrong they are flying some special audi tech to inspect my car has any one had this oil problem
    daworldisyours.com/forum<----check it out!!!!
    Nov 12 2007
    Stamford, CT
    Re: oil consumption problem
    mine eats a qt. every few thousand miles but nothing like your problem.
    Is there a leak?
    Dec 05 2006
    So. Cal.
    http://www.dysonanalysis.com/
    Have your oil tested and go from there. I wouldn't trust the Audi Mechanics.
    Dec 30 2007
    Constantly changing.
    DC
    Possibly VCG (valve cover gaskets)? Supposed common problem on the B6s.
    Senior Member Two Rings RedDevil's Avatar
    Dec 03 2005
    Maplewood MN
    Quote Originally Posted by wwb4 View Post
    I just had mine replaced, had oil all over the lower part of the engine/exhaust manifold and had no oil light at all nor was the oil level low. I'd think that if they looked at it and didn't notice any oil leakage there it probably wouldn't be the valve cover gaskets
    07 Phantom Black RS4
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Mine does the same.. and is a b7 s4 with 19k on it.. eats oil like a champ.. i come back from a 40 mile drive and see no oil on the dipstick.. what gives? ive had the car for 4 days now and its used a qt so far in like 400 miles.
    Dec 05 2006
    So. Cal.
    To all the new S4 owners. Rule one! Drain your oil when you purchase your car and put the good stuff in. It doesn't matter when the previous owner said that the oil was changed, drain it and refill it. This way you'll know what oil is in the car, how much went in and how much you are actually using.
    I would put some good German oil or Motul or something along those lies in the car. If you use Mobil 1 0/40 euro spec, expect to see your oil burning. It's good oil but thin, you'll burn through a lot of it. I would also do 3k mile oil changes for a little while. This may help with future oil burning issues.
    Also, don't overfill the reservoir. Up to the middle of the metal between the plastics are good enough. The audi dealer told me this on my brand new car.
    Mar 11 2008
    Pierceton, Indiana
    It was changed 3 days ago.. i got the cam adjuster fixed, and had an oil change done.. i think the compression test came out 125 on one bank and 110 on the other.. could that be the problem? HOW SO with 18k?
    Dec 05 2006
    So. Cal.
    What oil are you running? Since you had work done to the car I am assuming that they put n the Castrol syntec. Maybe a differnt oil will help with the problem.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Lubro-Moly :)
    'nuf said!
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Established Member Two Rings JohnnyG's Avatar
    May 03 2008
    too many....my audi: a4 b8.5 project
    LongIsland, NY
    I've seen rare instances of excessive oil consumption. It usually goes like this:
    customer says oil was low and adds oil.. comes in and oil is @ or near proper level.
    'cause they filled it
    can't verify concern..... so I'd tell 'em not to fill it, document level and mark drain plug.
    if they are back in 100 to 400miles (Ballpark) with low oil then there is a verified concern.
    That is the most important first step. Verification. Next step is oil consumption test and repair. But if they are flying in an engineer he can authorize a repair on the spot if he finds the problem. If not then they will do the test, drive it and check. If low a repair will be performed. The "policy and procedure" takes a little time. Update when you find out the engineers verdict.
    Mar 11 2008
    Pierceton, Indiana
    Actually the shop put some regular oil (Kendall) or something.. just to see if it has any oil use, since regular burns quicker than syntec.
    They did this because on my drive from where I picked up the car (NY to IN), i burnt 3 qts of oil (but i also had cam issues, and a miss in the motor, and no power) The shop fixed that issue, and wanted to see if it still used oil. I was supposed to go back in 3 days for a proper syntec oil change.
    Now my question to you is, since the valve cover WAS open to do the cam job, i do smell a little oil when i pop the hood, but thats probably from the Valve cover gaskets leaking onto the exhaust, bc the mech probly didnt tighten right or whatever it may be. But that should not lead to 1 qt being used after a 100 mile drive..
    I drive the car hard, but see no black smoke, even when i start it.. i do however see the exhaust tips turn sooty black within 10 miles.. i wipe them clean and theyre black again. so idk.. how can the car be burning so much oil withouth smoke?
    Dec 05 2006
    So. Cal.
    I think that everyones tip are sooty black. If they are going to switch out your oil, have them put in the Lubro Moly.
