Hi All,
I changed my oil and filter this morning. It took me 17 minutes with my larger capacity Pela Pro 14 oil extractor (I sold my smaller one to a friend).
I though I'd share the products I used for those interested…
The extractor is extremely easy to use (make sure the oil is warm, not hot). Just push the correct sized tube (you get three) down the dip-stick hole to the bottom and pump the handle a few times to create a vacuum. The tubes they provide aren’t quite long enough so you’ll have to raise the extractor off the groung a bit by placing it on a box or something. I use a plastic milk crate. While the oil is extracting I replace the oil filter. The filter is located on top of the engine, under the trim cover with the Audi logo, at the rear. You’ll see a black plastic domed cover with a plastic nut molded into the top…the filter is inside.
NEW- PELA PRO 14 LITER OIL EXTRACTOR
$109 Shipped from http://www.eAngler.com
OLD- PELA EXTRACTOR $79 from Griot’s Garage (fine for my Z, but too small for the S4)
OIL
Lubro Moly VOLL-Synthese (5 W-40 Full Synthetic Motor Oil) - 5 Litres x2, $35 ea. ($83.38 shipped) from http://catalog.etyparts.com/item.wws...y&clientid=ety
FILTER
Mann HU 835/1 x oil filter, $15.53 ea (pack of 4, $62.12 shipped) http://www.germanfilters.com/2004-au...k-p-55729.html
I also purchased a fuel filter but haven't installed it (I haven’t looked in to where it’s located...anyone done it?).
Mann WK 730/1 fuel filter for 2004 Audi S4 with 4.2 V8 engine
$12.58 each from http://www.germanfilters.com/2004-au...r-p-47526.html
Hope this helps, have a good one…Steve
