Results 1 to 16 of 16
    Senior Member Three Rings Murf's Avatar
    May 19 2007
    02 Audi A4 1.8t quattro
    New Jersey
    Removing interior paint?
    Hi I'm trying to repaint all my interior paint because a lot of it is peeling. I have already started and repainted the little hooks that are down on the driver and passenger floors. I started off by not stripping all the paint and just spraying over the old paint after a little light sanding. This just caused all the old stuff to flake underneath and it came out terrible. I also tried using some acetone to get the old stuff off but this was too harsh and was melting the plastic. I ended up just sanding all the old paint off but this takes a long time and before i start doing the rest of my interior i was wondering if anyone has come up with a better way to remove the old paint os has any ideas.
    2002 A4 1.8t 5speed
    STaSIS StreetSports | 19" Privat Reserv's | Pioneer AVIC D3 | Decorsa Street Exhaust | Boosted Tech CAI | | JHM Short Shift | Forge Splitter
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    Re: Removing interior paint?
    you should really try searching. There have been numerous threads on this topic and it never really ends up that great. If youve got an 02, youre going to have a shitty looking interior, unless you just shell out the money for new parts.
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    May 19 2007
    New Jersey
    I have tried searching. found multiple threads on buying the parts or touching up the parts that have peeled but what i want to do is just remove all of the peeling paint that is on there now and repaint it.
    2002 A4 1.8t 5speed
    May 31 2007
    Montreal
    Honestly I won't even bother.
    I just say to myself that I have to options
    Sell the car next year
    or make it my winter beater and get the S5 or Q7 for work.
    May 19 2007
    New Jersey
    Bump any ideas? I'm just looking for ways to remove the interior paint besides sanding.
    2002 A4 1.8t 5speed
    Established Member Two Rings JohnnyG's Avatar
    May 03 2008
    too many....my audi: a4 b8.5 project
    LongIsland, NY
    i found a way kinda by accident. Brake clean. Not the potent yellow can but the
    green can w/ LO VOC's written on the can. Best bet test it on an obscure item.
    Well maybe u can try it on the melted part cause that has to be scrap now.
    I just spray it for a couple seconds and watch the rubber paint curl and bubble.
    then wipe the mess off doesn't seem to bother the plastic. works best on switches, a/c head.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Brake cleaner. It will strip the color from the plastic, but if you're repainting it, it shouldn't matter anyway I suppose.
    SEM makes a special paint designed for plastics that bonds to the plastic and becomes "one" with it that would work really well for this. It's super strong and chip-resistant as well. Don't remember what they call it though.
    -Darrick
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Post pics when done please. I could see flat black paint coming out close.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 03 2008
    LongIsland, NY
    well the white you see under the rubber paint is the plastic, it is white so it will glow red w/ the led @ night. I never had the black plastic discolor....but I never soak 'em. I just spray, remove the rubber paint and wipe clean with a damp rag.
    May 19 2007
    New Jersey
    I finally got a chance to try brake cleaner and it worked okay for me. It still took a while to remove all the paint because i still had to scrape the paint off after i sprayed the piece with the brake cleaner. It didn't just come off like it did for JohnnyG but maybe i used a different type of brake cleaner. I used this paint to repaint the interior pieces:
    Here are the results (i only painted part that holds the window switches, not the window switches themselves):
    It didn't come out perfect because i missed a few spots when i was stripping the paint and i didn't have time to fix these spots before i needed my car. If you look closely you can see these spots but it still looks much better than it did.
    2002 A4 1.8t 5speed
    Dec 19 2007
    York, PA
    looks pretty damn good man, great job. the only fix you have to fix the console, a new one from genuineaudiparts.com is like $105.
    Mar 21 2006
    Lakeland, FL.
    It looks great, my only concern is how it'll wear. But then again that's what you're fixing anyway.
    I'm back bitches!
    Dec 19 2007
    York, PA
    threadstater..do you have to remove the door panel to get that piece out? Mines really bad too.
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    how do you take that thing off the door?
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    May 19 2007
    New Jersey
    You need to remove the door panel to get that piece off. I used this DIY http://forums.audiworld.com/a4gen2/msgs/998613.phtml.
    2002 A4 1.8t 5speed
    May 19 2007
    New Jersey
    Oh and for the window switches i just sprayed some paint in a bottle cap and used a paint brush to touch them up. I'm sure you could remove all the paint and repaint them but i wanted to keep those little symbols there.
    This does take a while to do because scraping all the paint off is a big pain in the ass. Like i said maybe i didn't use the right type of brake cleaner but if anyone does this and finds a better method to remove the paint please share because i still need to do this to the passenger side.
    2002 A4 1.8t 5speed
