    Senior Member Three Rings jetflyr's Avatar
    Nov 28 2006
    ‘03 A4 TQM Stage 1+, ‘07 FJ Cruiser, ‘18 Highlander
    Cincinnati, OH
    Rattle Under Acceleration???
    Hey all. Recently, I noticed a slight rattle under hard acceleration. It seems to come from the right side of the car. I pulled in the driveway and it does not seem to be the turbo, yet. It seems more a drive line noise. I have no codes but I do have the heatshield tapping noise when on a bumpy road like a lot of folks. Anyone have any thoughts? Maybe the same as the heatshield noise? I only notice it when acceleration right next to a wall or building w/ the windows open. Thanks for any help.
    '03 A4 1.8T QMS
    -APR Stage 1+, TT 225 Injectors, ECS/Hitachi E Coils, Samco Boost Hoses, Forge 007, ECS Snub Mount, K&N Filter, ECS Steel Lines, B+M Short Shift, AWE Pedals, ECS Rotors and Hawk Pads
    Nov 28 2006
    Cincinnati, OH
    Re: Rattle Under Acceleration???
    No One?? Please, someone must have some experience...
    '03 A4 1.8T QMS
    Oct 11 2008
    2002 Audi A4 1.8T Tip
    Connecticut
    Been having the same problem with my 1.8T. When acceleration from 2k-3k rpm, you can hear a loud rattle coming from the engine. Its very loud when in 2nd or 3rd gear but haven't had any problems in 4th or 5th. When in neutral no noise, seems like the rattle only come out when the car is accelerating hard. Any ideas people?
    Sep 25 2006
    '04 White 6spd 1.8tq USP
    Tampa, FL
    I had a similar problem which i just fixed, it was only in like a certain rpm range, like 2400ish, a metal on metal buzz/rattle sort of sound, happened on accel and decel sometimes, kind of like something metal in/on the exhaust was resonating, making it vibrate against something else metal very quickly. Search on here and narrowed it down to the fuel pump(didn't think it was that), a heat shield between the exhaust and drive line (or one of many other heat shields near the exhaust), a catalytic converter on its way out, or a broken exhaust hanger(ding ding ding!!!) It turned out to be the exhaust hanger closest to the engine, right after the down pipe, i have thermal exhaust and there are two metal strips that are welded onto the exhaust pipe(one on top and one on bottom), then they are welded to eachother at the other end (makes a little triangle) and that end is welded to another metal piece which is attached to the rubber part of the hanger. One of the two metal strips had broken loose on the end where they are connected to each other and it was just vibrating like a mofo, i jammed a thick piece of rubber in between them for the time being until i get around to getting them re-welded
    NOTE: if you examine your exhaust hangers make sure to give them a good tug because mine looked completely fine until i just randomly tried to move it out of desperation thinking i would never find the source of the rattle and it moved a little, enough to show me the crack where it had broken (damn those gigantic speed bumps)
    hope this helps i know i hated that damn rattle
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    I've had this happen with heat shields above the exhaust. Put it on jackstands and take a look around for marks where its hitting. Perhaps have someone rev the engine a bit while you listen to pinpoint where on the car the noise is coming from and go from there.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
