Results 1 to 9 of 9
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    Any way to disable citylights?
    OK, the color of the light from the citylights sucks (doesn't match the HID's). Since there are no replacements available (aside from melted housings and bulb out warnings).... I'd like to disable the citylights altogether. Is there any way to do this without getting a bulb out warning?
    I know a lot of people code their car for rest of the world to eliminate the ambers unless the headlights are on. I want the ambers, but eliminate the citylights. The ambers actually look awesome with Imola Yellow.
    Right now, when I want to run ambers without headlights on, I'm stuck with the citylights coming on too. I think it would look pretty cool to be able to just run the ambers only with no citylights.
    Thanks.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    Re: Any way to disable citylights?
    There is already sombody working on xenonmatch citylights without bulb out warning:
    http://www.audizine.com/forum/showthread.php?t=205250
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by lowestA4 View Post
    Thanks. I know about that already, but I think I'd rather not have citylights at all....or at least be able to turn them off. Besides, I don't want to modify my headlights at all and his stuff is still in the testing phase.
    Dec 20 2006
    CAN
    I hear ya, my inelegant solution was to pull the bulb out of the socket, use some high temp (up to 400F) silicone electrical tape to wrap the bulb up completely so no light is seen from it, then stick it back inside the housing for storage. Don't put it back in place, just leave it inside the light housing.
    Not sexy, but it works well without cutting wires and you don't get error messages on the dashboard. Completely reversible also.
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and more reasonably priced.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    I was thinking - couldnt you just jump the circuit with some metal wire?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by SuperAvant View Post
    That would just short + directly to ground. There would be no load. A resistor might work in place of the bulb though.
    Apr 15 2007
    in the middle of somewhere
    Quote Originally Posted by VR2V8 View Post
    resistor may get too hot??
    I am very interested to disable my citylights too. purely ugly
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by leo_yuen_ View Post
    Depending on the wattage. Higher wattage resistor would handle more power and wouldn't get as hot.......but the higher the wattage, the larger the resistor. So it might not fit so well in the housing....
    May 30 2007
    MA
    I just took mine out and plan on dealing with bulb out indicators...
    2014 R8 V10 - Gated
