Results 1 to 10 of 10
    Registered Member Two Rings
    Jul 29 2005
    Quebec
    Little trick I've found to shift into 1st gear!
    First, I bought a 2003 b6 with about 70k on it, shifting was not very good, especially into first on cold morning, and second and 3rd wered grinding, put some Redline in, grinding went away, but it's still feels veerryy tight on cold mornings. Have to do a full stop to get into 1st - anyway here is something I've discovered yesterday,
    When you are trying to bring it into 1st, push it in a bit, get back and push in again - It will pop right in! even with the car still moving, I was much suprised.
    Hope I'm not bringing back some old news though
    Dec 06 2007
    Re: Little trick I've found to shift into 1st gear!
    check ur snub mount that could be causing the rough shifting!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by youriy View Post
    I think You are :)))
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Check the motor mounts and/or tranny mount. They play the biggest contributor in the car not going into gear.
    -Sami-
    Sep 23 2006
    Houston TX
    I just give a little throttle to help go into first if I need it.
    Senior Member Three Rings zbrock06's Avatar
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    i sometimes have the same problem with 2nd and 3rd grinding for a second when i shift what would cause this?
    USP CLUB MEMBER #94
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    that would be a tranny flush,
    As far as getting it into first, hint towards secound gear, dont put it in, just tap it to the "face" of the gear, then go into first, What that does is it stops a couple things in the tranny from spinning and it goes right it.
    So said an audi mechanic.
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Quote Originally Posted by SportSter View Post
    I think it stops the synchronizers from spinning... and that's what I do too!
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    May 31 2007
    Montreal
    Quote Originally Posted by Ill 3.0 View Post
    I do this as well.
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by 617 Bones View Post
    Correct me if I am wrong...but,
    If ANYTHING they would be sped up....
    -Sami-
