Results 1 to 15 of 15
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Post Miles And Mods Thread!
    This thread is to give an idea to people with stocks cars what to expect when adding any type of performance hardware/software to increase engine output. We should list our mods and how many miles you have driven with those mods and any problems you've had. This should help most of us with making informed decisions. I'm piecing my kit together and would like to know what im getting into.
    Also I think we can add suspesntion, it's nice to know how long shocks/struts last
    for example:
    2002 a4 1.8tq
    56k miles, stock, blah blah blah....get the point.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Miles And Mods Thread!
    Hmmm.. interesting..
    2002 A4 1.8TQ 5spd
    95k
    Mods in the last 3k: 007 Forge DV (yellow spring), Evoms intake, AWE Catback Exhaust, Stasis SS Coilovers, GIAC FX with Siemens 380cc injectors, and Hiatachi "E" coils
    Notes: No problems/no codes
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    K04 status overhere. Basically no problems only thing is I blew a lot of hoses and minor stuff. Blew out engine, diff, tranny mounts. Clutch went very fast. When you upgrade you will need to keep up with all the other maintanance stuff.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Dec 06 2007
    ^^ how do u like the K04??
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by a4_1.8t_01 View Post
    Damn you did that with a k04? This is one of the reasons I'm hesitant to go BT. If a k04 results in " blew a lot of hoses....Blew out engine, diff, tranny mounts. Clutch" what does a BT do to the car? I'm not one to be messing with the car or paying someone to mess with the car to keep it maintained because of the changes caused by a bigger turbo. Just not good at that shit, I wish I was.
    Now that my car is out of warranty I really want to go BT. This thread will be interesting if the BT owners truly report on what has had to be replaced and what went wrong, and not just try to convince people that BTs are plug and play or problem free or have the same problems as a k04 .
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Jan 03 2008
    Columbus, Ohio
    52 views and this is it?
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    if u r goig BT u better be the one working on ur car..cuz im sure a lot of little stupid stuff is gonna go wrong.. with my k04 installed a month ago i haav an exhuast leak between my mani and turbo so we need to put a new gasket in there.. also had a few other tiny issues.. nothing big at all jus lil annoying stuff
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    02 - 60k - rs4 rear sway... No problems except for the usual leaks etc.
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Apr 05 2005
    lost wages, nv
    Oh I forgot
    02 1.8 fwd 69k
    GIAC software with Siemens injectors- no problems, running the GIAC for about 3 yrs and got the upgraded file, no probs. 35k
    Southbend OFE clutch for about a year and a half 18k - no problems at all
    Stratmosphere short shifter for about 3 yrs 35k no probs
    APR snub had to be adjusted once- had it for 3 years 35k
    s4 rear sway for about 2 years -no problems 20k
    Milltek exhaust for about 2 and a half years, the only gripe is a little one, the tips aren't totally centered but that's not a performance issue. 35k
    I've had a couple boost leaks and hoses replaced. who knows if it was cause by the GIAC software and inj. Also replaced water pump and front control arms, ESP module and coilpacks up the yingyang. A couple other things but can't remember offhand because they were all covered.
    <old school>
    Apr 05 2005
    lost wages, nv
    Quote Originally Posted by audikid66 View Post
    Yeah , so it seems. Whatever I do , I'll probably put the Samco or Samco-type hose replacements in there. Plus , I think the k04 software would be either free or really cheap because I have GIAC already.
    <old school>
    Senior Member Three Rings jetflyr's Avatar
    Nov 28 2006
    ‘03 A4 TQM Stage 1+, ‘07 FJ Cruiser, ‘18 Highlander
    Cincinnati, OH
    45K, w/ about 15 on APR 1+. Runs like a champ. Stock clutch is holding up well too, surprisingly.
    '03 A4 1.8T QMS
    -APR Stage 1+, TT 225 Injectors, ECS/Hitachi E Coils, Samco Boost Hoses, Forge 007, ECS Snub Mount, K&N Filter, ECS Steel Lines, B+M Short Shift, AWE Pedals, ECS Rotors and Hawk Pads
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    42K miles
    Stock
    AFE air filter [oiled] sometime after I bought it at ~36K
    RS4 Sway shortly after that
    replaced all 4 Coil Packs w/latest version about two months ago
    replaced fuel filter about a month ago
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    2002 A4 1.8TQ Tip
    50 miles - replaced one CP
    18k - RS4 sway installed
    20k - Revo stage 2 (or 1+), Milltek DP-back
    27k - downgraded to Revo stage 1 in preparation for sale of my car
    28k - replaced two CP's and cat last week
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    exactly!
    there's usually not any big problems or anything. but just little stuff. you're always tinkering with something. and i would be in debt up to my eyeballs if i took it to the shop everytime something acted up
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jun 30 2007
    Raleigh, NC
    ^the thing is that any car is going to be that way eventually... whether you modify it or not. i think learning to work on my cars myself has been one of the best money saving things ive ever done
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
