Results 1 to 16 of 16
    Mar 05 2007
    Paging RAudi Driver...
    I recently purchased H&R spacers and I believe I have the same problem you did with the mating surface not being the same diameter. I got 10mm for the front and 12mm for the rear and both are wrong. Neither pair has been mounted yet as I am skeptical of a possible safety issue. I spoke with a master mechanic who works on Rolls Royce's and Bentley's and he warned that the unequal surface could create a dangerous situation over time. According to ECS Tuning, they're the correct spacers. I'm thinking of saying "screw it" with H&R and just buying MTM 10mm front and 15mm back (i don't care about the understeer because my car rarely gets pushed hard). I haven't read of a single vibration problem with MTM spacers. Your thoughts and possibly part #'s for H&R. Thanks
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Re: Paging RAudi Driver...
    Quote Originally Posted by rgr121 View Post
    idk I have the H&R spacers on my S4 and I push my car plenty hard around the turns, straight aways I have no vibration or any other unwanted business. They seem fine. Are they the same diameter of the wheel no, but because of their hub-centric nature the work great
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    Quote Originally Posted by littleredwagen View Post
    x2 I've got 8mmFr./10mmRr. with my stock 18x8 wheels no problems at all.
    Dec 05 2006
    So. Cal.
    I you own an RS4 you're don't want to put on the standard H&R 10mm spacers. You need to go to H&R's web site and dial in the spacers for your application, i.e. 2007/08 RS4. A page will come up showing you all the spacer sizes and corresponding part numbers. However, these part numbers are not applicable to our RS4's. RS4 owners need to click on the footnote #24 and use those part numbers. Here they are below:
    If ECS is giving you some crap about the spacers, tell them to brush up on the stuff that they sell. I had an in-depth conversation with the guys at H&R about this and they said that you can't run the smaller spacers on the RS4 as it will cause problems. Whatever you do, don't toss them on the car. They are unreturnable once mounted. You will end up fighting with ECS to get them to swap 'em out, which they should since they dropped the ball on this one. Nobody ever looks at these footnotes and that's where the problem arises.
    Good Luck and keep us posted.
    Footnote
    24 If the hub face of your vehicle is 150mm (most vehicles have 135mm hub face), alternative spacers are available. Please see list below.
    DR = 8mm 162555719
    DR = 10mm 202555713
    DR = 12mm 242555713
    DR = 15mm 302555716
    DR = 20mm 402555716
    DRA = 20mm 4025572
    DRA = 25mm 50255712
    DRA = 30mm 60255712
    Dec 05 2006
    So. Cal.
    S4 owners, your applications are different so lets not mix this issue up.
    Dec 20 2006
    CAN
    RAudi, got any pics with the new spacers? I'm thinking of doing 10mm all around.
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and more reasonably priced.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Dec 05 2006
    So. Cal.
    Still waiting on them. I will pm you with some pics as soon as they are on. Should be by next week. Keeping my fingers crossed. FYI, 8mm are on backorder for two months. I am doing 10's all the way around.
    Veteran Member Four Rings PESAPC's Avatar
    Aug 19 2007
    B7 RS4 + B8 A4 Avant + JEEP SRT8
    Footnote
    DR = 8mm 162555719
    DR = 10mm 202555713
    DR = 12mm 242555713
    DR = 15mm 302555716
    DR = 20mm 402555716
    DRA = 20mm 4025572
    DRA = 25mm 50255712
    DRA = 30mm 60255712
    So, to be clear, you ordered ...
    DR = 10mm 202555713
    I still have residual vibration so I am willing to / interested in trying something new / else. How much? What is the URL?
    Did you look at this thread: http://www.audizine.com/forum/showthread.php?p=2449883
    Most particularly comments by Jeremy@Matrix re RS4 spacers?
    Thanks.
    B7 RS4 - JHM R-Clutch/LWFW/CP/Short Shifter + Milltek Exhaust + JHM Piggies&Tune + F/R Brembo BBK + HRE
    B8 AVANT S-Line FMIC + F Brembo BBK + BBS + STaSIS Exhaust + GIAC Tune
    BOTH Ohlins Coilovers + Rear Sway Bars + Michelin PS2 + Tint
    Dec 05 2006
    So. Cal.
    Go here:
    http://www.hrsprings.com/
    Type in your application, then click on note #24.
    Oh, and yes, the spacers that I have coming in are DR = 10mm 202555713
    Feb 15 2007
    Go here:
    I'm waiting to see some pictures of your car to make the ultimate decision. I think I may go with the DR = 8mm 162555719... Where did you buy yours?
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2023 Mini Cooper SE - White Silver Metallic
    Mar 05 2007
    I own an '07 S4 and...
    the spacers supplied by ECS don't match the stock wheels/hub diameter. I guess RS4 owners have the same problem. I'm pretty pissed as I have waited over 2 months for ECS to get them in stock and they turned out to be the wrong ones. These are the part #'s they supplied me with: 20255571 and 24255571. I now know that I need the same ones as you RS4 owners. I may just go with the MTM's and forget this nonsense and all the waiting around. What a headache!
    Dec 05 2006
    So. Cal.
    Re: I own an '07 S4 and...
    H&R's cost about $100 without bolts and MTM cost about $150 with bolts. So the MTM's will cost about $25 more per pair. Not bad for what you are getting.
    Is ECS going to give you a refund? If not then I would dispute the charge with my credit card company stating hat the company sold the wrong part that does not fit the car. You can get H&R to verify that.
    Aug 19 2007
    H&R's cost about $100 without bolts.
    Did you order direct from HRSPRINGS and how long a delay / are the two sets immediately in inventory / did they ship right away?
    Dec 05 2006
    So. Cal.
    10mm in stock, 8mm on a 6 to 8 week back order. i got the two sets of 10mm coming in and picked them up from the guys at Impex. They are a local shop here in San Gabriel that I hae been dealing with for over 10 years.
    Veteran Member Three Rings jerrym's Avatar
    Nov 23 2007
    4 Door Saloon
    i ordered 10mm from the shop i go to ..
    and im selling my current set to someone local :x
    thanks for the help ed.
    2009 Mercedes-Benz E63 AMG
    1997 Toyota Supra
    1994 Nissan R32 GTR
    2008 Audi RS4 (gone)
    2005 BMW M3 (gone)
    2003 Mitsubishi Lancer EVO 8 (gone)
    "After a certain point, money is meaningless. It ceases to be the goal. The game is what counts" -Aristotle
    Registered Member Two Rings rAudiguy's Avatar
    Apr 26 2008
    Berkshire
    Hi guys, I have 8mm on the front and 10mm on the back. you can use 10mm on the front if you're not planing on dropping the car. however if like me you plan to fit lower springs " I have the H&R ones" you will find with 10mm spacers on the front when pushing on through the bends the tyre rubs on the clip that holds the inside arch inplace. Only know this as a friend in the UK has just fitted 10mm all round with H&R springs and has had these problems. Hope that's of help.
