Results 1 to 34 of 34
    Registered Member Two Rings
    Apr 13 2008
    Westlake, OH
    :::I just really fucked up a "painting lowers" job :::
    I'm really really upset right now and wish I hadn't started this project. I thought all was going well with painting my lowers. Had everything done and waited an hour after applying clear coat to remove the masking tape protecting the rest of the car. Here is the result:
    [IMG][/IMG]
    [IMG][/IMG]
    the damn masking tape (green 3m automotive masking tape) pulled a **** ton of the paint right off the car. I currently have no idea what to do and want to kick myself
    suggestions? Thanks a lot for your time
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    Re: :::I just really fucked up a "painting lowers" job :::
    You're gonna have to redo it. Next time around, let it cure overnight (at least), and pull very slowly, away from the paint, at a 40-60* angle.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    ^^^ do what he said, sorry that sucks, I paint boats, and have had that happen too many times myself.
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    Apr 13 2008
    Westlake, OH
    how exactly would I go about "redoing" it? Use paint thinner and remove the paint/clearcoat?
    Jan 28 2008
    San Diego
    good heavens no. That would just smear everything around as its not cured 100% yet and will take you days to then wait for it to dry when it really looks like ca ca before you can sand it off. Ask me how i know this....
    Wait till it gets about 2-3 days in some heat. (atleast 60) or one day in high heat (like 90's) Sand it with 300 sand paper. Taking it back to plastic/primer. Then Prep, then, re-primer, then paint steps..
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    brings back memories of when this happened to me...i was so fucking pissed
    Dec 08 2006
    Cincinnati
    Couldn't you remove the tape/paper carefully just after spraying the clear coat? In essence, why not just remove the masking tape/paper (covering car) after spraying and letting the paint settle (no paint in air). That way none of the paint on the lowers would be pealed off when removing the tape. I am sure other ways will work too, but just seems like a simple solution.
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    If you use paint thinner, the plastic will be fucked up..
    Just sand it and repaint it..
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
    Feb 27 2005
    North Wales, PA
    next time run a razor blade on the edge before you peel.
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    Quote Originally Posted by Poopie View Post
    Bad advice. Many people don't have a steady hand and will cut to deep. Right thru the paint into the metal and then it will be source of rust.
    Best advice is to unmask it while it's still wet...just wait for it to tack up a bit.
    FYI I used to paint cars.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Why didn't you just take the lowers off the car to paint them?
    Sold:1997 Audi A4
    I'm guessing because they almost always break in the removal attempt. I know I had to destroy my old ones to get them off to replace them.
    Alex
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    EXACT same thing happend to me when did mine. I just re-masked and re-sprayed the parts that got F'ed up and it was fine.
    Jan 26 2007
    Charleston SC
    Quote Originally Posted by Burntaudi View Post
    the only thing is , most people do at least 2 coats and i did like 3 coats of clear. you can't unmask each time. I used the razor blade... hopefully i didnt cut too deep
    Feb 15 2007
    marimont
    FYI plastic doesn't rust.
    Jul 07 2004
    socal
    Thats odd, I just took mine off to have molds made of my doors and mine did not break at all. But then I also live in socal where the weather condition doesn't kill car parts.
    BTW you most likely mean the small plastic tabs on the back break when removing the lowers, those are cheap and can be bought at the dealer.
    Apr 13 2008
    Westlake, OH
    haha well here in Cleveland the salt in the winter just tears apart our cars its really terrible. I already had to replace the passenger plastic piece because it had become completely corroded. But I guess I'll sand it all off and try again. Gunna be a pain in the ass.
    Registered Member One Ring audi5150's Avatar
    May 03 2008
    so cal
    Quote Originally Posted by FACT View Post
    [IMG][/IMG]
    [IMG][/IMG]
    yep best bet , pull tape off while paint is still wet ...
    Apr 13 2008
    Westlake, OH
    Quote Originally Posted by audi5150 View Post
    wouldn't it still do the same thing seeing as how the underlying paint will probably be almost dry by the time I'm done clearcoating?
    Senior Member Two Rings Durkin's Avatar
    Feb 17 2007
    '88 Nissan 300zx Shiro #341
    South Carolina
    couldn't you remove the masking tape, then let it dry and re-apply the masking tape and clear coat?
    Sold:1997 Audi A4
    Quote Originally Posted by audiness View Post
    I didn't mean pull the tape off between coats. If your letting the paint dry completely between coats your letting it dry to much. You just let it flash between coats and pull the tape off after the last coat.
    Quote Originally Posted by solowb5 View Post
    Really no shit? You do know the moldings are metal under the rubber and that there is a metal stud that holds them to the door...and guess what they rust.
    Guess yours were fine because of where you live. Where I live mine where rusting and needed to be replaced. The screw was also frozen into the molding.
    I know what you mean about the plastic however thats not what I meant mine where fine.
    Alex
    Established Member Two Rings mark_2328's Avatar
    Apr 04 2007
    Fargo, ND / Brainerd, MN
    Happened to me also, but worse! Got so mad haven't gotten around to doing it again, worried it will do the same thing.
    2000 S4, Autothority chip, H&R Sways, basically stock..
    Feb 27 2005
    North Wales, PA
    true...i have hands like a surgeon though
    Jan 15 2007
    san jose
    make sure to pull the tape off away from the new paint when your removing the tape
    Veteran Member Three Rings Davect06607's Avatar
    Apr 07 2007
    Bridgeport, Ct
    How long for this "flash"?
    '05 S4 6mt- Jhm 93 tune, Jhm IM Spacers, H&R c/o's, 034 Density Motor & Trans mounts, Hotchkiss Sway Bars f&r, Apikol snub & R.Differential mounts, 034 snub bracket, Jhm LW rotors w/ Hawk HPS, K&N, Piggies, FI Catback w/ 8" resonators, S.S. brake lines, 034 Density strut mounts, 034 MAF Hose, 034 adj. endlinks, RNSE, JHM Solid ss.
    Sold:1997 Audi A4
    Quote Originally Posted by Davect06607 View Post
    Depends on the weather. But just long enough so that surface drys...but it's not dry all the way thru.
    Alex
    where do you buy paint to do this?
    contact via email please.
    Apr 13 2008
    Westlake, OH
    If you want an absolutely perfect match you can get it from a place like paintscratch.com but it is pretty expensive. People have been getting perfect or near perfect matches using duplicolor products which are only like $5 a can and can be bought at autozone
    Veteran Member Three Rings B5 SLPR's Avatar
    Dec 04 2007
    B7 S4 Avant
    So Cal/La Jolla
    what colors are you guys using, I am goin to be putting skirts, rear valence and a new front bumper and i need to pain them. anyone know what paint to use to get the best match?
    "I like to party"
    VMR, Great Wheels, Great Company http://www.velocitymotoring.com/
    Apr 13 2008
    Westlake, OH
    for my 01 silver a4 I used duplicolor "radiant silver metallic". I had to go to like 3 stores to get 4 cans though because it seems like none of the places had more than one can of it. I'm thinking maybe they're not making that color anymore. Not a huge deal however as duplicolor has at least 8 shades of silver, many of which would still match as well if not better than what I used.
    Veteran Member Four Rings loustylez's Avatar
    Oct 03 2006
    2001 A4 2.8 QT
    kansas city
    ugh, i need to repaint my lowers again soon. i didn't sand down the bumps in the plastic first but did everything else and now it's cracked.
    anyone got any pics of the reiger V1 sides with oem bumpers? i'm considering having those painted and put on as well unless it won't look right. my car is silver obviously.
    Jun 25 2007
    Phoenix
    Has anyone found a match for Laser Red yet?
    Sep 23 2007
    Rip the tape off right after you paint it i do this with paiting all the time this way the paint is still wet and has less of a chance of chipping like that
    Apr 13 2008
    Westlake, OH
    Well everyone i ended up waiting a day and a half for the paint to dry completely then took an xacto knife very gently to the border of the tape and the paint and it did a pretty decent job... not 100 percent perfect but not too bad. If I were to do it all over again I probably would have taken the guy above me's advice and taken the tape off before the paint dries except I don't really understand how that is entirely possible. You have to first put on the primer, wait 5 mins and then put on a few layers of paint, then wait an hour before applying clear coat. The paint is pretty much dry to the touch after an hour so how could you remove the tape while the paint is still wet? You still need to have the car masked when applying clear coat...
