Results 1 to 13 of 13
    Established Member Two Rings keith's Avatar
    Jun 03 2007
    AUDI A4
    farmingdale, new york
    change/credit card bin stuck
    my creditcard/change tray is stuck in and i have no idea whether i should try prying it out or not, i tried prying it out and the faceplate where it has the little picture of credit cards on it popped off. idk what to do
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: change/credit card bin stuck
    give up! haha...its not that useful....just put the stuff in the storage bin under the seat :up:
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Jun 03 2007
    AUDI A4
    lol, yo im having all sorts of problems today if u can't tell
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    mine got stuck before so i hit it a few times and was able to get it open enought to fix whatever was keeping it from opening, now i dont cram as much stuff in it.
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Jun 03 2007
    AUDI A4
    should i try to pry it out or should i keep bangin the shit out of it
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Quote Originally Posted by keith View Post
    keep bangin'
    thats what she said
    2003 A4 1.8T
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    yeah, that thing is a piece of shit. I beat the shit out of my CC holder and I finally got it unstuck! Little did I know that it would only be stuck open! My advice to you: bang all you want on it, but just expect to buy a new one if you want it to actually function.
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Mar 26 2008
    do you know whats got it jammed?
    16MAR09DSWHTAW
    Jun 03 2007
    AUDI A4
    it got stuck once before and i fixed it by just bangin on it but this time its being a bitch lol what i think is messing it up is when u put a lot of change in there it falls through the back and fucks it up
    Veteran Member Three Rings dfresh000's Avatar
    NNJ
    funny thing is the dealer told me - its not for coins LOL $150 to fix, yeah right. got my stereo shop to release it from underneath & now its just of no use. that bin thing sucks.. release it & let it be
    '13 Monsoon Gray S4 P+ | DSG | Carbon Atlas | B&O | Sports Diff | More Fun to Come
    '14 Monsoon Gray Q5 3.0T P+ | B&O
    In Limbo One Ring
    May 03 2008
    Waterloo, New York
    had that happen to me once, i pryed on it a little bit, the plate came off, then i pryed somemore and it popped out!
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Use a flat screwdriver and gently pry up on and back it beside the red light.
    It's under a hundred dollars for a new one, and if you do replace it don't use it for anything other than cards or such... just thin, flat items that aren't likely to slide/fall behind the dash.
    GL!
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Established Member Two Rings JohnnyG's Avatar
    May 03 2008
    too many....my audi: a4 b8.5 project
    LongIsland, NY
    you could pop off the trim above it (console colored trim just below your metal/wood/plastic decorative dash trim.) then it should be easy to pry it open. use a plastic trim tool or wedge so you don't damage the finish. Don't store any change or small items in there or in your ashtray, they will jam and break....
