Results 1 to 11 of 11
    Senior Member Three Rings LowSantorin's Avatar
    Oct 19 2007
    Dub State
    HELP! Loud noise while driving!
    When driving straight ahead or turning left my car constantly is making a loud drone/hum which sounds liek it is coming from the back. Just got brand new tires today and it still does it. However if i turn right the noise is gone completely. There is no rubbing or anything. Any Ideas?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: HELP! Loud noise while driving!
    I wanna say that your wheels are not balanced right
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 14 2006
    Halifax, NS, Canada
    rear wheel bearings
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    wheel bearing
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Oct 19 2007
    Dub State
    ^that was what i was thinking it might be too. Guess ill check it out tomorrow
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    left rear wheel bearing
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Its an easy job and about $100 to fix yourself
    Village Idiot!!!
    (\__/)
    (")_(")
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    I bet it's your wheel bearing.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Mawhitey View Post
    RIGHT rear wheel bearing
    Fixed.
    If the noise stops while turning right, the issue is on the right side. The reason the noise goes away is b/c you're unloading the suspension. This works the same as you're making a left hand turn, the suspension loads from the weight transfer to the right hand side. make sure it's from the rear before you go Gung-Ho on it and waste your time.
    95% sure it's the bearing just from how you described it.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Just take a stethoscope and turn the wheel by hand to listen for any abnormal noise and feel for resistance.
    Jan 20 2005
    99 AJL TQS
    UK
    Yeah you right, i get confused. I should read properly, My bad
    -Mark -
