Results 1 to 9 of 9
    Veteran Member Three Rings jojoampt's Avatar
    Jan 19 2008
    02' A4 Avant, 1.8T QM, 08' S-Line A3 MT
    Humboldt County
    exhaust question
    i decided to go with custom exhaust instead of just ordering one, so i went down to a shop and talked with the guy. this is the setup he thinks would be good, was wondering what you guys think... no flaming im pretty much a newb
    (leaving cat in) 3" downpipe to the y, to 2.5" pipe with glasspacks on each pipe after the y, to 4" tips...
    sucky? or does this seem good? he said if i dont like it he'll put mufflers or whatever i want with no labor charge so mine as well try i guess.
    Saint Cloud, Fl
    Re: exhaust question
    That's a big DP do you plan on going BT ?
    instagram ------------> low_enforcement
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    do u have to?? I'm only running lltek intake and mjm dv... and my custom exhaust from engine-back is being made right now... 3", no cat, and magnaflow mufflers... might add resonators after y if it rattles or too raspy.... should I not put it on untill I get my ko4?
    Jan 19 2008
    Humboldt County
    I do.. but not in the near future.. cars got 120k on the clock so needs a rebuild before thinking of any real power. gotta get all the supporting mods as well. you think 3" is too big from the cat back with stock turbo?
    Quote Originally Posted by 7speed View Post
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    Can you run a 3" with the stock cat? I thought it was 3" to 2.5" dp.
    Jan 19 2008
    Humboldt County
    i think youre right, he was talking about a small piece of 2.5 to match up with the flange on the cat and then to 3" like a tiny coupler i guess he just felt like doing it entirely of 2.5" would be too small
    Quote Originally Posted by Killerteve View Post
    Nov 09 2006
    02 A4 1.8TQM
    SF
    If you don't mind losing your cat you can get a full 3" test pipe for pretty cheap. There's not really a point of doing 3=>2.5=>3. Plus I think 2.5" is good for up to at least 300hp of flow, so unless you plan on going bigger than a gt28 in the future you should be good with 2.5".
    Jan 19 2008
    Humboldt County
    im gonna keep the cat for now.. so i should probably just go 2.5" all the way back then. do you think it will be seriously loud with glasspacks instead of mufflers with the cat still on?
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    I have a TP and no resonator w/ Thermal Custom 3" and I set of car alarms
    <<NO SIG>>
