Results 1 to 11 of 11
    Established Member Two Rings mathieums's Avatar
    May 05 2007
    Audi A4 1.8t Quattro 1997
    Montreal, Quebec, Canada
    Water infiltration
    I have some water getting in. Its following the firewall from inside and it accumulate under the driver seat.
    I don't have a sunroof. I've checked pretty much everywhere and I couldnt find anything.
    I sent the car to a windshield repair place and they tried to see if it was leaking through the windshield "glue" and they told me its not from there...
    I'm pretty much clueless... Where the hell does it come from?
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Re: Water infiltration
    My car is doing the same thing I don't know where it is coming from but pretty much half way under the seat and back gets soaked. If you figure it out let me know.
    Senior Member Three Rings Mad_Audi's Avatar
    Mar 06 2006
    97 Amulet Red Audi A4 1.8T
    Greenville, NC
    i had water come in through my cabin filter after a hurricane. i had 6 gallons on my passenger side floorboard. didnt notice till i came to a stop sign in my neighborhood and all 6 gallons came rushing forward lol. make sure your molding that sits against the windshield is on properly. that was the culprit in my scenario
    Veteran Member Four Rings Burntaudi's Avatar
    Sold:1997 Audi A4
    Maplewood, Minnesota
    2 things to check. 1 there is 2 drains under the battery make sure those are working... otherwise your firewall area will fill with water. 2 make sure there are no holes in your ECU box there is a huge rectangular hole under the ECU leading to under your dash. If the plastic box isn't water tight water will get in thru this area.
    Alex
    Sold 97 Audi A4 Turbo Quattro Manual
    KO4/GIAC PC-16/GHL Exhaust/EVO FMIC/ Southbend Clutch/JHM Short Shifter & Linkage/Shifter Bushing/Koni Coilovers/Neuspeed Sways/17" OZ Superellegras/Ecode Headlights/VVME Hids
    Current ride 03 Tahoe Z71
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    So it could either be the cabin filter or molding around the windshield? An is the molding on the outside? Thanks.
    Cool thanks for the extra input.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    my guess is clogged drain under the battery
    Mar 06 2006
    Greenville, NC
    the molding that i speak of is the peice of plastic that lies against the windshield on the exterior of the car.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Don't forget to check next to the ECU box. It's almost under the fender and far up in the corner.
    There's a grommet that seals the rather large hole for the hood release cable. I could not get mine back into place on my old B5, for the life of me. Fortunately the newer one doesn't have that issue.
    Another place to check is below the vacuum booster, there's a couple holes down there for the clutch master cylinder.
    May 05 2007
    It was coming in from the ecu box. Here is the project completed!
    FINAL RESULT:
    Registered Member Two Rings
    Dec 28 2004
    pennsylvania
    looks good, nice job on doing it right.
    I seem to have those kind of things happen to me, stuff that just happens and so you just have fix it before it gets worse or causes other problems, even though theres other stuff you would rather be doing.
    99.5 a4 1.8tqm
    93 318is
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    damn that looks like fun project
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
