    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Lack of TT owner interest in the Stasis GB?
    Hey there fellow ring lovers...-
    I just noticed that you guys seem to have 0 participation in this group buy i'm organizing.. i don't want you guys to miss out ..
    you can get your sets for at least 16% off and up to 21% ..if we see some more support from people like you!
    non quattro and quattro are both supported in this GB.
    the time window is very small... come check it out .. and sign up !
    http://www.audizine.com/forum/showthread.php?t=207936
    Registered Member Two Rings myownstylett's Avatar
    Apr 14 2008
    02 Audi TT 225- 06 Explorer
    Oak Harbor,WA
    Re: Lack of TT owner interest in the Stasis GB?
    Not to bust your bubble but you can get Ksport coil's with 36 ways to adjust for 30% off They go for for $1300 and they are $909 out the door free shipping. http://www.bshspeedshop.com/store/home.php?cat=656
    MY SECOND WIFE :D CLICK AND SEE HER
    URL: http://www.carsponsors.com/profile.php?id=172457
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    ***temp omission, orig post avail from me still****
    Apr 14 2008
    Oak Harbor,WA
    The Ksports are not part of Koni. They are a different product. The only reason I said something is cuz you utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do and get a better range of adjuastment with Ksport then Stasis. I was going to go with Stasis but I couldent beat the fact that they give you 36 ways of adjustment and you can go as low as 4" if need be. Not that I would go that low. But if Iam correct and chime in if I am wrong but the stasis only goes 47mm. The one thing that you got me on is I payed alittle more for my Ksporst then I sould of unless shipping is not free then it would be close. This is the first time I have heard of Ksport and thought I would give it a shot. Also I did some research and found nothing bad said about them. I will write a review after the install. You are doing the right thing and taking advantage of a good deal. That's what I would do.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    good luck man! wish you the best
