Results 1 to 8 of 8
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Pic request: ' 02 with lowering springs
    I have an 02 A4 and I know they are the lowest. I have a set of eibach pro kits and I an hesitating on putting them on with blistens so I'm Looking for some pics of 02 with lowered suspension(preferably lowering spring not coil overs)
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Pic request: ' 02 with lowering springs
    A lowered 02 will only sit about 1.5" in the frt. and .5"-.75" in the rear lower then stock sport, at least mine does.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Yeah, mine too. Once the stasis Group Buy goes through it will be a little bit more then that.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Quote Originally Posted by dirtybrd View Post
    Do you have any pics
    Dec 06 2007
    Basically any lowered A4 on springs would look the same, because in 02 all that was different was the height of the springs and when u swap those out same as any other lowered A4 with springs!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    I had the pro kits, dont instll them u wont be satified with the hight, go with some NS sport springs
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Quote Originally Posted by gotboost View Post
    How won't I be satisfied? To high? Or to low?
    Veteran Member Four Rings norcatalyst126's Avatar
    Galt, CA
    Pics?
    I just installed Vogtlands and height wise there is really no difference....although i love the tighter ride......cornering is so much more fun....
    need rotors?...adam's rotors
