Results 1 to 13 of 13
    Registered Member Two Rings HIGH SPEED QUAD's Avatar
    Mar 05 2008
    Denver
    Dual cupholder???????
    Has anybody moved the ESP switch and ditched the blank and put in a seccond retractable cup holder??
    Any help would be appreciated..
    92 UR S4
    02 S6 Stock for now
    Established Member Two Rings Digga's Avatar
    Jun 18 2007
    FL
    Re: Dual cupholder???????
    God that would be nice! I tell everyone my biggest complaint of my car is cup holder space!
    Current
    FOR SALE
    2013 BMW 335i M Sport
    MPE/Dinan springs/Rotiform
    http://f30.bimmerpost.com/forums/sho...d.php?t=998376
    Former
    04' A6 2.7T ~APR 93 OCT Tuned
    -APR R1 DV's, Eibach Sportlines, RS6 lip spoiler
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    i don't have the esp button
    instead i have a business card holder.
    i've broken that and the cupeholder too... time to order two, almost time... shit even the back ones are broken... ahhh
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Registered Member Three Rings projectdarka4's Avatar
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    what is an esp button anyways? i dont have it either way
    Jun 18 2007
    FL
    Quote Originally Posted by projectdarka4 View Post
    electronic slip protection... aka traction control
    It electronically controls the power from the engine as it transfers to the wheels, if a wheel starts to slip it will power down and adjust to gain traction back.
    At least thats the way i've always understood it.....
    Current
    FOR SALE
    Former
    Mar 05 2008
    Denver
    I guess I will order one and see if it works.
    92 UR S4
    02 S6 Stock for now
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    Search on Audiworld, there was a DIY writeup on it. It was for a B5, but should be the same.
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    man that fucking swicth is useless, i think when your turn off traction control, it turns back on like over 30 or somthing, so dumb. and if you didn't want traction, why did you buy an AWD audi?
    2004 Audi A6 2.7T
    Senior Member Two Rings Switchblind360's Avatar
    Feb 26 2006
    '01 allroad 2.7T TIP, '95.5 S6, '91 200
    Boise
    Tray to Cup holder - EASY (5 minutes), just take a couple of small flat head screwdrivers and lift the brass tabs slightly above the tray.
    Now, cars with the ESP button may have a more difficult time.
    '00 Audi A6 2.7TM
    HB Nefmoto Stage 3
    '91 Audi 200 QTM 20v
    TAP Stage I
    '01 Audi allroad 2.7T TIP
    Homestyle Nefmoto Stage II, 402 Mod
    '95.5 S6 QTM 20v
    034 Stage I
    Mar 05 2008
    Denver
    Thank you glad to know someone has done it and its possible.
    92 UR S4
    02 S6 Stock for now
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    in NJ, the business card holder is the change holder for tolls!
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Oct 06 2007
    Georgia
    not a great thing to do as you have a lot of items below it that when they get wet have to be replaced buddy of mine is a service writer and they see a far amount of damage due to drinks I have an 02 s6 and wont a card holder to replace my cup holder on the dash.
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    a guy with an allroad moved the cupholder and the air suspension controls form one side to the other, so it can be done, but he didn't write it up. Not sure where you could relocate the ESP button to though -- good luck.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
