Results 1 to 7 of 7
    Oct 24 2006
    River Oaks
    80K service ,.....what should be done.
    My dealer is running a special for $650 for timing belt replacement. What is usually replaced w/ this service? pumps, pullies?
    Another shop quoted $900 but told me they were going to replace more than just the timing belt.
    What should i demand the dealer to replace?
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Re: 80K service ,.....what should be done.
    water pump, tensioner, belt....that i know of.
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Quote Originally Posted by budfox View Post
    $650 at a dealership? i'm going to guess labor isn't included?
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    no way is it 650 for just parts, i bought my parts for 225, thats everything Pump, Tensionr and belt.
    Mar 27 2005
    The Cold North
    $650 for the timing belt job from the dealer seems too good to be true.
    Here's what ECS includes in their Timing Belt Replacement Kit package:
    ECS Timing Belt Kit
    OE timing belt made by Continental
    OE tensioner Roller made by Ruville in Germany
    OE tensioner assembly made by Ruville in Germany
    OE Idler roller (comes on the tensioner assembly)
    Hepu water pump with metal impeller
    4 OEM crankshaft pulley bolt
    Accessory Drive Belt
    Camshaft seal
    Crankshaft seal
    (2) 1.5liter of G12 coolant
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    That isn't to bad even if it is just labor... if you aren't doing it your self, I would buy the parts from ECS or another distributor since they will be much cheaper. The stuff mentioned above is what you want. The Camshaft seal and crank shaft seal may not need to be re-placed. I bought them just incase when I did mine but they were good. You may also want to check out the local forum for you to see if anyone near you would be willing to help you for cheaper.. GL
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    my local dealer quoted me 2,000$ for timing/serpentine belts, tentioner, water pump, fuel filter......
