Originally Posted by
phukenA
Hey Guys,
Im in need of some serious help here. I am experiencing the problems of Cam lobe wear (fuel cut/limp mode after high RPM's etc.) I am 99.9% sure that after doing weeks of research that this is my problem. Here is the real issue: after taking my car in for a fault code (low pressure fuel regulator) twice now, and asking both times to have the cam lobe wear checked (with 2 different dealerships) I've gotten nowhere. To make things worse, I am now past my warranty period. Now I know that there is a TSB out on this issue, and knowing that it costs roughly $5000-$8000 to fix, my question is this: Will Audi cover this problem with the TSB out on it, or am I completely out of luck here?
What do you mean you didn't get anywhere?
What was the diagnosis for the faulty code?
What caused the code? What was the repair?
Did the dealer/s and tech/s do anything?
What's on your service/repair tickets from the Audi dealers?
If you have the receipts/repair tickets specifying the particular problem, then that should help you get resolution even though you are now out of warranty. I assume you're out of warranty due to mileage, not time?
IOW, you have had to requests for service to investigate and repair a known issue that has a TSB. At the particular time that the dealer "looked" at the issue, they claim "no problems found".
Do you KNOW for a fact that you do have the actual problem?
If so, how do you know?
It seems you had error codes before indicating a problem, but, what was the fix for those codes?
I think Audi of America will help you out and have the problem fixed.
However, you may need to take your Audi to a different dealer and have them address the issue, because it seems the last place you went to had some incompetent tech's.
You need to get the problem identified first and foremost.
Make an appointment and take your Audi in to the Audi dealer and ask them to find out the problem. I'm guessing you have another "check engine" light or stored codes?
