Results 1 to 12 of 12
    Apr 14 2008
    2008 A4 SE Quartz Gray 2.0T
    Some basic Revo Stage 1 Questions
    Hi,
    I am enjoying my 2008 A4 SE very much & while I have not made it to the 1000 mile full throttle mileage yet, I will be doing that soon. It got me thinking about chipping. I am fortunate to have a Revo dealer 5 miles from my house (Driversport). So I think that is the way I will go.
    I am not planning any big mods for my A4 (Tinted windows & the chip sounds like a no brainer).
    I was curious about:
    1. When you have revo installed, do you drive in Sport mode or Drive mode?
    2. When the software is installed, does the installer do anything or is it a "vanilla" flavored installation? Does the installer "tune" the car or is it just out of the box?
    3. Are reflashes typically free?
    4. How many miles should be on the car before flashing?
    5. I have seen mentions of a switch to turn the software off when your servicing the car. How does that typically work? Is there a button or something?
    6. Are the long term effects of chipping known? Will this hurt the longevity of the car (I tend to keep cars until 100k-120k miles)?
    7. What tends to break when using Revo? I have seen mentions of something called a "DV". Is that expensive to replace?
    Thanks,
    Rich
    What will likely break?
    Oct 01 2007
    Location, Location, Location
    Re: Some basic Revo Stage 1 Questions
    1. Either, but sport lets the turbo spool more and you can feel more of a difference.
    2. Its vanilla, but with revo you can tune the software yourself if you want to.
    3. Yes (unless you are charged an hour for labor, depends on where you buy it)
    4. I don't think there is a required amount (although it should be broken in before driving it too hard)
    5. For revo you must purchase the revo selector (which has a switch), for apr its controlled throught he cruise control
    6. Not sure
    7. A diverter valve (dv) is the most likely thing to break or tear because of the increased boost that the chip makes it hold. They cost around $250, but once you replace it with a forge Diverter valve it shouldnt break again.
    Senior Member Three Rings womensecks's Avatar
    Mar 07 2008
    2005.5 avant, 1991 e30
    torrance//socal
    1. either or, doesnt matter. it will perform like stock drive or sport will, but with the extra chip *umph*
    2. vanilla only
    3. define reflash, as in the dealer resets your ECU due to recall issue or software update? usually yes, but some shops charge a "reflash fee"
    if you update to say .. a testpipe and need a reflash, then no, not free
    4. some usually say 1000, but you can chip before and just drive as you would before the 1000 mile mark/service.
    5. switch to turn off software costs extra $$ for revo. APR has it as well, but theirs is through the cruise control mech. and not sure if its extra $$
    6. longevity, it is known to throw the DV in cases ... however it just depends on how heavy your foot gets when chipped. with higher boost, youre gonna give the internals a more intense workout and this will lead to overall increased wear, not sure how much more, but it will.
    7. as mentioned above, the DV is the diverter valve which is typically a bypass valve that helps relieve boost pressure... correct me if im wrong, but you have an 08 SE, which tend to have lesser problems with it, and yeah, its fairly inexpensive to replace.
    i love you
    2005.5 b7 a4 avant 2.0T quattro, sold
    1991 e30 318is coupe
    1988 e30 m3
    -theworks
    Apr 14 2008
    Quote Originally Posted by masteroc View Post
    Is a Forge DV hard to replace? Is that a DIY project?
    Oct 01 2007
    I have never done it myself, but i hear its not that hard. There are some how-to's about it in the ...guess where.....how-to section!!
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    The diverter valve is a little hard to get to. But it's a german car, everything is hard to get to. There is a DIY out there, but I just had my tuner shop throw it on for me while I was getting some other things done to it. I think they charged me $50 to install it.
    Apr 14 2008
    So the question is, if I plan to stick with a Stage 1 Revo & not upgrade the exhaust (or the DV) should I opt for the Revo with the:
    Select: 199.99
    or
    Select plus - 349.99
    I really think the only thing i will do is swap between stock & performance modes. Stock is only for the dealer. The Revo dealer said they could reflash for free & if i had to goto the dealer they would disable it, then enable it after the work is done at the dealer. I think for $200 bucks I should do that myself (it might be a waste but if I have a problem & then have to go to the revo dealer to turn off the program, that will be a big PIA).
    Any ideas on if the Select Plus is worth it for stage 1 only?
    Thanks,
    Rich
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Is APR anywhere close to you? They have a sale right now for $599 you get 2 programs and it switches by the cruise control.
    -Kris
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Quote Originally Posted by RichTJ99 View Post
    Select: 199.99
    or
    Thanks,
    Rich
    not really for stage 1. the vast majority should be fine with the regular select switch
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Apr 14 2008
    I think I will opt for the regular select switch then. APR is pretty far from me so I think I will opt for Revo. I like the idea of not having to send the ECU out for servicing.
    If I go with the Revo 93 software & my wife decides to use my car, cheap out & buy 87, what happens to the car?
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    buy the select plus switch. yes it costs extra money but you can tune it for cheap gas all the way up to race fuel. (cheap means 91 octane, dont mess with 87 ever). you say right now that you wont do too much modding but once you get the flash youll be hooked and end up wishing you bought the better switch. or you could buy no switch and find another member who has one and just use his :) i would take a drive to your revo dealer and ask him all your questions. build a good relationship with the dealer cuz chances are youll be there more than once.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    DONT PUT 87!! it messed up your turbo/engine . 93/91 only.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
