Results 1 to 19 of 19
    Active Member Two Rings 01Audi1.8T's Avatar
    Apr 08 2008
    2011 Toyota RAV4 Sport
    New Freedom, PA
    VAG-COM code: Searched but couldn't find
    Hey guys,
    I searched for this code but the only thing I found was people cleared it and it never came back.
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-00 - -
    I cleared it but it came back. Not sure what I need to do to fix it. Any ideas?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: VAG-COM code: Searched but couldn't find
    google "wiki Ross tech" a site similar to wikipedia will come up and just enter the code
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 04 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Quote Originally Posted by biketsai View Post
    Huh, good info, worked for me, ya, my MAF sensor is dying.
    P0171.
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Apr 08 2008
    New Freedom, PA
    That code is not on the Wiki.
    Deactivated Four Rings
    Nov 19 2006
    MMM
    Wow, thats not even in DTC Xpress
    Apr 08 2008
    New Freedom, PA
    Help anyone?
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Quote Originally Posted by 01Audi1.8T View Post
    Hey guys,
    P1650 - 35-00 - -
    Sounds like either a bad cluster or a broken wire that communicates with another module, is it an auto or manual?
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Apr 08 2008
    New Freedom, PA
    It's a manual. At one point, the check engine light was not wired up so I figured that was why it was coming up and so I cleared it. Not sure why it came back. The only other thing I can think of at the moment is the mpg calculator in the information center doesn't work right. It only displays 5.0 mpg all the time. The rest of the cluster works fine.
    Apr 08 2008
    New Freedom, PA
    Any other ideas?
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    abs light on?
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Did you scan the instruments module for DTCs?
    "You know you have a bad idea when Ford guys are making fun of you."
    Nov 19 2005
    WA
    I couldn't find that code on my Bentley at all however, there is a code 18057: Data Bus Powertrain Missing message from ABS Control Module.
    The manual says to test the resistance between two terminals on the ECU, but my guess is the terminals are difference since the codes are different.
    I'm thinking it sounds like the ECU is dying, or you have a short somewhere in your CAN-Bus system.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Apr 08 2008
    New Freedom, PA
    Quote Originally Posted by infinkc
    abs light on?
    Nope. No lights at all.
    Quote Originally Posted by chris164935
    How do I do that?
    Apr 18 2007
    Orange Park, FL
    How do I do that?
    Simple: click on the button circled in the picture in VAG-Com.
    If you don't get a response then it means that your instrument cluster needs to be replaced. If you do get a response from the controller, then select "Fault Codes - 02" and report back with the codes, if any.
    Apr 08 2008
    New Freedom, PA
    I tried your steps chris. I get a response from the cluster but no codes. That code is coming from the engine module.
    Apr 08 2008
    New Freedom, PA
    N E 1?
    Apr 08 2008
    New Freedom, PA
    Still looking for some help with this
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    I dont suppose you put a used ECU/Chip in have you? Maybe it needs recoding
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Apr 08 2008
    New Freedom, PA
    Quote Originally Posted by Mawhitey View Post
    I haven't. Previous owner could have.
