Results 1 to 8 of 8
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Looking At This Gauge...
    Ok, So after the whole thing with my S4 and the motor blowing up I am thinking about investing in a wideband O2 sensor and A/F gauge. This is the one I am looking at:
    http://www.innovatemotorsports.com/x...e630356ee5b1d6
    What do you guys think? Have any of you used it? Also how do you install one of these? I mean if I have this O2 sensor plugged into the gauge is there another plug to plug it into the ECU? Not sure how the setup on this goes.
    If any of you have any other suggestions for good A/F gauges and Wideband O2 sensors please let me know.
    Thanks
    josh
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Re: Looking At This Gauge...
    Quote Originally Posted by ThePaintballGuy View Post
    Thanks
    josh
    Heard only great things about Innovate stuff. Trying Scott @ US Rally Team. He distributes for them and his customer service and prices are awesome.
    Once the turbo fairy comes I am sure I will be purchasing one of these to go with my setup.
    Cheers
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    I think you would have a hard time beating this combination: boost and wideband AFR
    Or you can choose any two readings you want.. oil pressure & AFR, AFR & EGT, etc.
    Details are here: http://www.audizine.com/forum/showthread.php?t=203082
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    anyone want to buy a brand new zeitronix zt2 wideband o2? i bought one like 2 weeks ago, then the next day my friend gave me his old one! its still brand new in the box. never opened
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Jun 14 2007
    2000 S4
    Connecticut
    BTW, innovative widebands are also sold @ VAST Performance....
    Senior Member Three Rings archimense's Avatar
    Jan 16 2006
    Vancouver, Canada
    Quote Originally Posted by [email protected] View Post
    SECOND!
    [Sorry I haven't returned your message Winston :(]
    2001.5 Audi S4 stg 3
    K04s, 85mm MAF, 60lb injectors, custom software
    ASP DTS/Tru-Dual/Downpipes
    Stasis Tracksports/4:1 Centre Diff
    Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
    VAST ceramic clutch, RS4 pressure plate, JHM shifter
    RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
    Jun 14 2007
    2000 S4
    Connecticut
    does that podi guage log? like with the innovative tons of info can be gotten from them.... is that an electrical gauge or does it go in the O2? sorry i havent done any searching on it lol
    Jun 11 2005
    Vancouver, BC
    The VEI guage shown is a display that takes in input from a wideband AFR controller just like the Innovate product in the OP link.
    The gauge display itself does not log anything, the Innovate LC-1 controller that I pair the display with does.
    The combination package I have put together has the same AFR functionality as the Innovate package you are looking at since the LC-1 controller is made by them.
