Results 1 to 12 of 12
    Apr 19 2008
    ct
    boost leak test help
    i just bought a awe built leak tester is it suppose to hold pressure or just leak out did it and i hear a a leak from back of the motor some where anyone have any idea why
    Veteran Member Three Rings RuS4ty's Avatar
    Mar 13 2006
    VA / MT
    Re: boost leak test help
    annnnd..... period.
    no it's not supposed to leak
    *NEW Addition: Misano Red RS4
    01.5 S4
    For sale(pm me for details):
    FRONT AIRBAGS !CHEAP!
    Stock S4 swaybar
    "I'd have one of those... if I were the sort of person that looked at my sister and thought, mmm..." - Jeremy Clarkson about the Roush Mustang.
    Dec 06 2007
    Calgary, AB, Canada
    Spray some soapy water in the area you hear the hissing coming from. That should reveal where the leak is.
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Its not like filling up a balloon. You are pushing pressurized air through the system. It will make noise, but you shouldn't feel any air coming out anywhere if you stick your hand behind the intake.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Apr 05 2007
    fill a spray bottle with soapy water and spray the area you hear the noise coming from. You will see bubbles start to form where the leak is. My guess is the brake booster line t-fitting.
    Apr 19 2008
    ct
    do u have to put constant air through it or is it suppose to hold the air
    Apr 19 2008
    ct
    because we put a valve stem to the tester and soon as i fill it it will be empty within 15 seconds and the boost gauge wont go past 10 pounds on the gauge while filling it
    Aug 10 2007
    Castle Rock, CO
    Quote Originally Posted by b5s46speed View Post
    You have to hook it up to a constant 15-20 psi supply (air tank/compressor with a regulator set to 15-20 psi). So yes, there will be constant pressure flowing through the system as long as the compressor has enough pressure in the reservoir.
    Its not a balloon. You are pushing air through the system, not filling it with air and looking for leaks. You need to put 15-20 psi into it, because that will make the leak obvious and will replicate actual possible operating pressures.
    Registered Member Two Rings BillKlineVT's Avatar
    Nov 04 2007
    2001 Audi S4
    NoVA
    make sure you block off the breather/pcv port on the y pipe
    Bill K.
    2001 Silver S4 - AWE Stage 3
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    I preformed this test last night and all I could hear is the air pressure going into the y-pipe or leaking behind it, very loudly! Checked all hoses and couldn't find anything...also did the soapy water. What could be leaking so bad underneath the y-pipe? Also, if I have a mbc hooked up, should I do the leak test with just the n-75 valve in place instead?
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    lol, i need to pressure test my car, just havent made it to home depot and got a fitting to connect it with my air compressor...but damn do i have a leak, it bounces up and down when hitting boost...not sure what it is...but will findout soon enough bosses...any idea what kind of fittin fits on the intake tester, im in dc and dont have the part with me so i can take it in and see what connection..so if anyone knows, please let me know so i can go and get it without having to go home and get it.
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    May 23 2008
    Columbia, SC
    should just be an industrial style 1/4" female air coupler
    http://www.airhoseshop.com/site/932654/product/IC4M
