Results 1 to 9 of 9
    Established Member Two Rings zackcamp's Avatar
    Jan 14 2008
    81 Rabbit Diesel, 91 GTI VR6t
    Virginia Beach, VA
    19x8.5 front, 19x9.5 rear, how will they fit?
    I'm looking into buying some wheels off a friend and was wondering what the general opinion is in this? I haven't received info on the offset yet, which I know is a major part. Hopefully I will have soon.
    Im running 19x8 up front and 19x9 right now and there doesnt seem to be much room left. Is rolling my fenders gonna be the only way to pull this off? Please let me know
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: 19x8.5 front, 19x9.5 rear, how will they fit?
    same as I run, no fender rolling necessary
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    It all depends on the offset and the tire choice.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings BlackB6's Avatar
    Apr 03 2008
    Pennsylvania
    Pics? I was thinking of the same setup.
    Jan 14 2008
    Virginia Beach, VA
    I'll probably be pulling the General 265/30's off the rear of my RS6 Reps. Pics would be appreciated just to get an idea. I'll post offset when I get the info.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    19 x 8.5 up front et28 (because of the brakes) most come et32 235-35-19, 19 x 9.5 et 35 rear 245-35-19
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    Offset is the magic word here. I believe anything between et32-38 should be OK. et35 is best. Also your tire choice will also make a big difference. Too big on the rears might make things tight.
    Veteran Member Three Rings audimymind's Avatar
    Nov 26 2007
    Mililani, Hawaii
    i went with 19x8.5s with 225/35/19 in the front and 19x9.5s with 235/35/19 in the rear fits perfect and im waiting to lower my car...
    Apr 03 2008
    Pennsylvania
    Quote Originally Posted by audimymind View Post
    I just checked out your car, they do look perfect. What offset did you go with?
