Results 1 to 10 of 10
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    how to remove heavily worn brake rotor
    ok, i've included a crappy pic to try to illustrate....
    I am changing out my brake rotors, and they are so heavily worn that the caliper with the pads cannot slide past the outer-most part of the rotor, which is not nearly as worn down as the rest of the rotor. So there is a lip on the edge... any body ever had this problem before?
    Nov 15 2007
    Audi A4
    Redding, California
    Re: how to remove heavily worn brake rotor
    a big screwdriver and some elbow grease got mine right off
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Easy. Take a large C-Clamp and with the caliper still on the rotors, place the C-clamp on the outer pad that you see through the caliper opening (the large C shaped hole) and other part of the clamp on the back of the caliper. As you start turning the c-clamp, it will compress the piston in giving you space to separate the brake pads and full them out real easy.
    Just like in this picture.
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    Hardest thing is gettin that caliper off
    Bolts were in there like a U know what
    If you get the right leverage and the right power they'll give and youll be on your way
    Its all about how you go at them that matters and yes a big screwdriver and the rotor will just fall off
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
    Jan 26 2007
    Charleston SC
    Quote Originally Posted by nebone22 View Post
    thanks man, this sounds like it will work.
    I'll give it a try.
    Thanks for the quick responses everyone
    Nov 19 2005
    WA
    Yea sounds like the pads are getting stuck on the lip of the rotor, caused by wear. All you need to do is compress the piston to clear that lip and it'll slide right off. The c-clamp method will work, or just take a big flat head screw driver and put pressure on the pad backing plate, both will compress it enough for you to be able to get it off.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    Open the bleeder screw on the caliper before compressing the piston.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Not the bleed screw but rather the brake fluid reservoir cap.
    Oct 10 2007
    ON, Canada
    Actually, the proper way is to open the bleed screw to push the old fluid out. You will not let air in the lines since gravity forces fluid down, not up (that's why the screw is on the highest point of the caliper). You don't want to be pushing used fluid back in to your master. But hey, to each their own.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    this is what i do to every car that i do brakes on at work...
    stick a pry bar/screw driver into the slotted part of the rotor, pry against the caliper using the slot as your pivot and leverage point... you will compress the piston enough to get the caliper off, i actually compress the caliper all the way using this method so i dont have to grab a pair of channel locks later on to reinstall it
