Results 1 to 34 of 34
    Feb 27 2005
    North Wales, PA
    Swapping AEB into a 2001 awm a4
    Is there anything thats too different that will cause me trouble? As far as knock sensors and stuff? I have a complete motor ect. I'm looking to pick up a 2001 avant 1.8t now.
    Veteran Member Three Rings RAyala2.7T's Avatar
    Mar 08 2005
    Austin, TX
    Re: Swapping AEB into a 2001 awm a4
    it is illegal to put an older engine in a newer car. so unless you don't plan on registering it you should be okay. as far as electricals and all, i'm not too sure since there will be some things missing from the aeb that the awm wiring harness needs to connect to.
    Rob - 2000 Audi S4 VAST Stage III
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    who would know the difference when it comes to registration? the only problem you would run into (which would be avoidable) is when the inspection station hooks up the obd port to check the diagnostics
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Aeron keep the AWM as it its going to allow you to run no MAF, swap rods and AEB head and call it a day. The tuning potential of the 01' as you know now allows more options in programming...Unless going SAEM
    97 A4 2.0TQM
    Rochester, NY
    I don't see why it wouldn't work, it should run on the 2001's engine mgmt too. I believe one of the engine mounts is different and obviously the accessories are differen't but it shouldn't matter in your case since you have a whole car to take parts off of.
    We know the AEB head works on the 2001 engine mgmt, so it's really just a matter of the VR sensor and knock sensors working
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Quote Originally Posted by RAyala1.8T View Post
    i think that varies from state to state, because it's not illegal here.
    Feb 27 2005
    North Wales, PA
    dddooohhhhhhhhh....I know the aeb will swap into a 2000 with out much head ache since the bottom ends are the same. Ok well them i'll have to just pull the rods and pistons out of the aeb and put them in the awm block.
    Anyone selling aeb pistons? Maybe i'll just fully rebuild it....damn!
    Feb 27 2005
    North Wales, PA
    No one would know its and older engine since the stock engine management is still there. The inspection people at pepboys don't know the difference between a cat and a large flex pipe.
    97 A4 2.0TQM
    Rochester, NY
    Quote Originally Posted by Poopie View Post
    i'll have some for sale soon, i would have had 4 from my donor motor but i dropped one and it got dented so i'll have to take the good ones out of my other motor to make a set :(
    i still think you could just drop all your stuff in, add the map sensor on your piping before the TB, the wideband o2 sensor, and whatever else it needs.
    Apr 11 2007
    Baltimore, MD
    Why don't you sell your motor and start over? 06B offers you some more options than 058
    '97 A4 Quattro - 5speed, 12v AFC 2.8
    '01.5 A4 Quattro - 5speed, 20v AWM 1.8T
    Feb 27 2005
    North Wales, PA
    I've grown fond of my motor....
    who wants to buy my motor then? taking offers....
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    why is a vr-t not in your thought process? i know you can do it!
    you've got some extra cash to throw around after you part out your old car right?
    get off computer > go to yard > buy 12v longblock > I think you know the rest!
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Registered Member Two Rings SilverB5A4's Avatar
    Jan 19 2007
    RIP '01 A4 1.8TQM, 96 VR6 GTI
    GA
    Sell the motor, buy an aeb head, scat rods, aeg crank, 83mm pistons, wala you have your self a 2.0 awm. Problem solved
    GIAC chip - Koni coilovers - Purems Boxster calipers and A8 rotors - CPP Adjustable Front and Rear upper control arms - H sport sways - B7 S4 BBS CH 18" - 2.8 transmission
    Feb 27 2005
    North Wales, PA
    i actually got hosed really bad by insurance. I don't even wanna talk about it. Getting hit really effing sucks.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    swap the internals over to the new motor, swap an AEB head on the new motor, go from there... dont over complicate it poops
    Feb 27 2005
    North Wales, PA
    yeah. I'm trying to do everything on a budget now. Before i was gonna buy a 2000 avant..but the deal fell through. It was the perfect car to buy....well i can't find a decent a4 avant anymore. People are asking way too much for their cars these days.
    Oct 27 2007
    In the lab
    sucks insurance didnt treat you right... this is why i deal with bare bones insurance, i figure the money i save will go towards an accident if i ever have one, and if i dont i have some money on my hands...
    Veteran Member Four Rings SurferForever's Avatar
    Nov 28 2006
    01 A4 1.8TQM
    Warren, NJ
    Quote Originally Posted by SilverB5A4 View Post
    good luck tryna find scat rods these days. Nobody is able to order them
    Natasha: 01 A4 2.0 T28/T04 || Silver (Fastest Color)
    034 Motor and Tranny Mounts | Full 3" exhaust with HFC | APR Snub | B&M Short Shifter | APR Boost Gage | RS4 Grill w/ Custom Matched Lowers | 8000k Headlights | 3000K Fogs | M3 Lip Spoiler | Reiger Roof Spoiler | Debadged | Clear Corner Mod | Independent Fogs | Dual Rear Fogs | Zimmerman Cross-Drilled Rotors | Mintex Pads | SS Braided Lines | 18X8 Black ASA AR1's
    Feb 27 2005
    North Wales, PA
    integrated engineering rods will do.
    Feb 15 2007
    marimont
    Keep the AEB engine together. Just swap the AWM oil pan to the AEB bc it has the oil sensor unlike the AEB. Also you will not have VVT on the AEB. I forget if there is a sensor at the back of the head or not on the AEB. Yes keep the AWM software as stated before you can run mafless and just use the map sensor. It's also nice that you don't need to use the damn ignitor that the AEB uses. Also AWM coils need a little of the rubber trimmed on the coil packs to fit the head. That is all. Hope that helps.
    Feb 27 2005
    North Wales, PA
    so you're saying swap the aeb into the 2001? just switch oil pans? I can put the vvt cam chain tensioner into the aeb head if I choose to. Yes, i definitely want to keep the awm ecu and such.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    You also need to keep the newer IM as the injectors and DBW throttle body etc or is that taken as read??
    I would be dropping the AEB in, with the newer IM and maybe an AEB head, with the correct sump and VVT job done.
    I had to go the otherway and put an APU ( small port) engine into my AEB engined 1998.5 A4
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Feb 27 2005
    North Wales, PA
    I think I can still run the aeb intake manifold and just put the DBW throttle body on.
    Jan 20 2005
    99 AJL TQS
    UK
    I thought they had different sensors on them (IAT Specifically),You will also need the newer oil pressure switch as the connector is different to the AEB.
    -Mark -
    Feb 15 2007
    marimont
    He is reffering to the injector seats might be different. Atleast I think that is what he is talkng about. If you run the AEB manifold you will need to run the AEB injectors and fuel rail as they sit different then the AWM. IAT is the same.
    Jan 20 2005
    99 AJL TQS
    UK
    I knew the injectors and seats, i wasnt sure how they would affect the running ect with different rates/resistances .
    It must be a Euro/US difference as i remember my APU having a sensor thing under the bottom of the IM.
    At least if Poopie swaps it all over and it doesnt work, he has it all there to swap one bit at a time i suppose, so do it Poopie AEB FTW
    -Mark -
    Feb 27 2005
    North Wales, PA
    I"ll just figure out what works and what doesn't. I think the fuel rail will work. It has to or else i can't use the manifold since its a returnless system. I can probably swap the oil cooler set up to keep most of the plumbing the same.
    Feb 15 2007
    marimont
    The AWM has a fuel return. Well my AWM does atleast. I've swapped over to the AEB also.
    Feb 27 2005
    North Wales, PA
    nice, ok well it should go pretty easy. I have a deal for a 2001 audi a4 1.8t santorin blue agant in pristine condition. Hopefully picking i up for 6 - 6.5k
    Sep 24 2005
    always in design
    Poop you're basically going to be doing exactly what u did. AEB head on AWM bottom end...
    The injector seats and the AEB intake mani from the AEB with the TB from the AWM. You get the 2001 and just mix and match the best of both worlds.
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by solowb5 View Post
    yeah, i was going to say. returnless fuel systems didn't start until 2002. which is
    Current:
    Previous:
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Poopie you could use the aeb in the 2001 body. You have to switch oil pans, throttle body, some vac lines because the ports are opposite on the intake manifold. Also I use the Aeb head and mani and have no problems with the stock injector seats. And get the uni 630 file written for no cat, no sec air, no maf, and no vvt. It can be done. Thats what I use now just with vvt until I get cams. And no MIL
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Feb 27 2005
    North Wales, PA
    I gotta give my props to tapp. Hes taken care of me. I gotta call and make sure i can still pass inspection with a cat delete and sai delete. If not, I'll go with a uni tune.
    Oct 01 2008
    Philly
    You need to run an aeb rail with awm injectors with injector spacers. The awm injectors will fit in the aeb seats perfectly with a tiny touch of trimming.
