Results 1 to 11 of 11
Thread: Help w my DEPOs
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Help w my DEPOs
    So I am utterly confused on how to hook up my headlights and I need some help. I am trying to figure out what i need to do with all these harnesses and stuff and im not sure where to cut what wheres as well as what wires to connect to where. And yes i am following the DIY. Any help would be appreciated.
    This is the original headlight harness. It has 4 wires a white/black, white/green, yellow/black and a brown wire.
    This is the blinker harness that has three wires. White/black, grey/black and brown.
    And the harness that connects to the new depo's. its has a peach/red wire that i connected to the low beams, Peach/ blue for the high beams that also offshoots to the city lights as well as a yellow wire. Which i have all that figured out except how to hook up to the actual car for power.
    and lastly on that same harness is three more wires brown, black and blue that i dont know what are for.
    So can someone explain in english how to connect these.
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: Help w my DEPOs
    the last 3 wires are for headlight leveling (you probably don't have this), the others I cant help with since it's been a while since i wired my euro's
    -richard
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: Help w my DEPOs
    what year is your car?
    Jan 11 2007
    texas
    Re: Help w my DEPOs
    98.5 A4
    Oct 28 2006
    Re: Help w my DEPOs
    that was directed at the OP...but if you're pre 99.5 you need to buy a new connector since the older style ones are round and will not fit
    Oct 02 2007
    Lone Tree, Colorado
    Re: Help w my DEPOs
    i thought this was to eliminate the connector. But yeah im 99.0. So is this the ecs connector everyone talks about.
    Oct 28 2006
    Re: Help w my DEPOs
    Quote Originally Posted by jrock View Post
    yes you need to rewire your existing headlight connectors and you reuse the OEM bulb holders for the corner lights
    Oct 02 2007
    Lone Tree, Colorado
    Re: Help w my DEPOs
    how to you change out the bulb holders? i am also missing the drivers side blinker bulb holder if thats what you are talking about.
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    Re: Help w my DEPOs
    u could use the one from the old headlight, just need to dremel a little bit of the edges, but when i had my 96 i just stuck it in there with force, works fine.
    try it, cant understand man, its so easy to figure out once u have the headlight out.
    good luck.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Oct 28 2006
    Re: Help w my DEPOs
    Quote Originally Posted by prey View Post
    x2
    Oct 02 2007
    Lone Tree, Colorado
    Re: Help w my DEPOs
    thanks guys ill order the harness tomorrow cuz i am done messing with it. In the mean time i cut my fenders so that i can fit the lights in. so far they look b-e-a-u-tiful.
