Results 1 to 13 of 13
    Oct 31 2005
    Ashburn
    I think it's my turn= TURBO LADY
    So one the way home today i gradually give alittle gas and turbos start screaming really loud and then i let off, i thought something happened so i get into alittle bit again and the car started shakin boost gauge was stuttering and the turbos sounded like someone was scraping fingers nails on a chalk board
    So i literally drove home out of boost cause i didn't want to be sitting on the side of the road with my car smoking. but i made it home, only thing is after my incident with the Heads and everything i broke as hell.
    I think my plan will be get a beater car and then work my ass off and save money and decide which path to take, only thing is this car still need control arms and some new shocks(but i'll get coilovers) and i don't like the feel of my gears when i shift so might go with JHM tranny rebuild. all in all i have a hell of alot of money to come up with. sad thing is i have a goo job but other bills are in the way, but none the less i will be joining the STAGE 3 CROWD
    sorry for the long post, also any suggestions?
    - Instagram: @Sinister_rs5-
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Re: I think it's my turn= TURBO LADY
    i feel like a lot of these cars are biting the dust recently.
    SBSC
    I also like to live dangerously.
    Oct 31 2005
    Ashburn
    Quote Originally Posted by FrimmelNoJerz View Post
    I know, i would have sold it earlier but who's going to buy a stage2+ with 108,000 miles on it for 14,800 cause that's what i owe.
    Doesn't matter know, just hope the turbo upgrade install goes better than it did when i got my heads done.
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Sorry to hear that bro, I recommend saving up and doing everything once the right way... Also try and buy the k04's and inlets asap.. as the price for them is increasing... if your not completely ready to go stage 3 perhaps you can find some k03's pretty cheap and DIY the job if your up to the task... could end up being cheaper then buying a beater car... although im sure having a small 4cylinder beater would save you tons of money on gas.. lol..
    Senior Member Two Rings hachirokukid's Avatar
    Mar 22 2007
    00 S4, 07 A4 2.0t
    nc
    another one bites the dust...
    sorry to hear that man...
    just try to keep your mind on the finished product...
    good luck
    Veteran Member Three Rings ChumbaWumba's Avatar
    Jun 06 2007
    damn...sorry to hear that man...keep ur head up
    Oct 31 2005
    Ashburn
    Thanks guys
    After talking to my girlfriend(which i thought she would be alittle upset after the Heads incident) She told me, "well we both have some money to save up then don't we"
    I think she will contribute to my new world of STAGE 3
    i think i'll be fine. but i will make sure this is done correctly and hopefully no problems will exisit after i'm done.
    I might go K03, again and save if i can get it done cheap enough. my drive to work is only 15mins so gas is not an issue.
    Sep 21 2006
    Norjerz
    its been my experience that even when you fix everything thats wrong with the car theres still always something wrong.
    SBSC
    Oct 31 2005
    Ashburn
    I know but i think that if this doesn't work out and i want to sell it it will atleast be stage 3. with all maint. done and records.
    will just have to see what happens.
    you getting that Benz or staying w/Audi?
    Dec 12 2007
    Boston
    Sorry to hear! It must be that ECU!
    Believe me stage 3 is def worth it!
    Although there is something else to fix now! haha
    Good luck!
    2001 S4
    Stage 3 totaled...
    new- 2001.5 Nogaro
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Thanks guys
    Wait. There will be complete bolt on gt2560 kit coming this summer for under k04 price. You will be able to keep your stock exhaust manifold. The kit will be ready this summer. I've odered one. go to http://boost-engineering.com/ and talk to Louis. He is the owner of the company. He's a good guy. The other thing is that your dollar is a bit stronger than ours right now. Too bad what hapened and good luck.
    Oct 31 2005
    Ashburn
    Quote Originally Posted by Reich View Post
    Yeah, but the way things have gone with this car i want something alittle more proven. and possiable something i can DIY if it all works out. Not going full stage 3 just yet, i just need some turbos to bolt on with some stage 3- software and then i can have time to build the rest in a timely fashion without spending all my money at once. But i will weight my options and my mind might change so will see.
    Oct 31 2005
    Ashburn
    Quote Originally Posted by sweed View Post
    Good luck!
    Yeah i blamed that ECU for everything. LOL def. wasn't the cause of my doorlocks issue but i'll work that out later
    i'm looking foward to this. i should be happy and not sad.
