Results 1 to 14 of 14
    Established Member Two Rings bavaria75's Avatar
    Feb 13 2008
    02 A4 3.0QM - 04 Passat 1.8TM
    San Jose, CA
    Hot or cold engine oil change?
    What is recommended, better.
    The car is sitting since about 2 weeks in the garage unmoved, so all the oil
    and dirt should have settled nicly down in the oil pan and can be flushed out?
    or
    Dirve the engine hot and flush the oil hot as it flown better out of the engine?
    Shouldn't matter but its for my wifes 1.8T.
    Thank you for your opinion or input.
    2002 A4 3.0 Quattro Manual
    Feb 17 2008
    Re: Hot or cold engine oil change?
    I always do it when its hot on both of my cars.
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    you make a nice point about all the dirt being settled at the bottom. with that point in mind, i'd drain it cold. throw some cheap oil in there (non synthetic is ok for this), drive it around for a little while, 50 miles or so with some seafoam in there. drain it hot, and put in some quality full synthetic 5w40 oil in there such as elf/quartz 9000.
    it'll cost a little extra to do this obviously, but would be a nice flush for the engine imo.
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    I usually like to do it after the car has cooled off a little so I don't burn myself, but maybe that's just me. I personally don't think that it makes that big of a difference but I'd wait at least like 15 minutes after you drive the car for a while for it to cool a little bit and so all the oil will go back down to the oil pan.
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    IMO ^^^^ I secound that
    what oil would you put in the car to clean out the oil from sea foam before you changed it again with synthetic?
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    Oct 22 2005
    Reppin the Mitten.
    warm
    Veteran Member Four Rings 3ohAvant's Avatar
    Mar 10 2004
    east bay, CA
    as hot as you can stand. for me, its pretty warm, but not hot.
    do it after a 10+ minute drive. then by the time you have it jacked up, and belly pan off, it should have cooled down enough to not be freaking scalding.
    the reasoning. you want the particles suspended in the oil when you drain it. if its settled. its settled, and its not gonna pull the crap from more than an inch from the drain hole. so everything that has settled will still be there.
    - Benny
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Changing the oil cold is the worst idea...ESPECIALLY after the car jas been sitting for two week.
    All the residue and sediment have settled at the BOTTOM of the oil pan, its not like they are suspened in it. The only bit of sediment that will come out, is the unlucky bastard that is right over the drain hole. Always, always, change the oil when it is hot (after a loong drive)
    But once you have drained the oil, after that, wait for everything to cool down before going in for the oil filter, if you dont want to burn yourself
    -Sami-
    Veteran Member Three Rings Dos::Avants's Avatar
    May 30 2007
    Garage no more :-(
    'sconsin
    Also, after two weeks, there may be some condensation that NEEDS to be burned off.
    The particles are suspended when hot, as well as the ease at which the oil drains will save time. I usually wait about a half an hour for it to drain with the oil cap off.
    Avanta-Humpa-Lot
    Aug 08 2007
    A4, GTI, Corrado
    Jacksonville, FL
    Get the oil hot before you drain it... don't worry about "dirt" or other particles going through the engine, that's what the oil filter is for.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    I change it hot, then again I use a fluid evacuator so no chance of burns.
    -Kris
    Feb 13 2008
    San Jose, CA
    Thanks for all your input.
    With your arguments above It came pretty clear to me that an engine should always be drained hot/warm.
    I changed it late last night run it for 15min and drained it and good to go again.
    Thankns again.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    it also drains better when its warm
    May 21 2007
    Florida
    it honestly doesnt matter one bit. the only difference will really be that hot oil is thinner and will drain faster and leave less "sludge" than thick, slow draining cold oil will.
    2018 Navarro Blue Q5
