Results 1 to 13 of 13
Thread: Oxygen Sensors
    Apr 07 2004
    San Diego, CA
    Oxygen Sensors
    Quick question, I know i have a bad O2 Sensor, should i replace the front or rear one first? I know the front one is easier to do but i am not concerned about that. They both cost the same on ECStuning, (both are $115 each). AWM Engine Code.
    "All the dude ever wanted was his rug"
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Oxygen Sensors
    are they BOTH bad?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Apr 07 2004
    San Diego, CA
    Re: Oxygen Sensors
    Not sure, it could be both, could be one. I dont know.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Oxygen Sensors
    How do you know the 02 is bad? The first one is the important one and the 2nd one just says if cat efficiency is good or bad.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Re: Oxygen Sensors
    vag com?
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: Oxygen Sensors
    front is the only one that affects engine performance, rear 02 just tells the ecu that the cat is working.
    -richard
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    Re: Oxygen Sensors
    if either on of them goes bad it will throw a code.. is it throwing a code... if it isn't then they are most likely fine.. scan it for a code and it will be either bank 1 or bank 2.. and then you know which one to replace!!!
    Jan 11 2007
    texas
    Re: Oxygen Sensors
    Quote Originally Posted by baboom View Post
    If it's a v6 it will show bank 1 or 2. if it's a 4 cylinder it's only bank 1.
    It will say sensor 1 or sensor 2.
    sensor 1 is closest to the engine, sensor 2 is after cat.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Apr 19 2008
    215 PA
    Re: Oxygen Sensors
    yes sir
    Established Member Two Rings Urbndevelopmnt's Avatar
    Jul 04 2007
    2005 A4 Cabriolet, 1996 A4 2.8
    East Rutherford
    Re: Oxygen Sensors
    are they the same part though or do they use different connectors?I have a spare front O2 sensor but bank 2 went bad :(
    Jan 11 2007
    texas
    Re: Oxygen Sensors
    Is is bank 2 sensor 1 or sensor 2? bank 2 is the side of the engine since you have a v6 it appears bank 2 is the driver's side. someone chime in if i am wrong on this.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Apr 07 2004
    San Diego, CA
    Re: Oxygen Sensors
    Thanks for the help, Yeah it is throwing a code, CEL light has been on for some time. I will have to re-check it, My car is a 4-cylinder, so i guess sensor 1 would be pre-cat and and sensor 2 is post cat?
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: Oxygen Sensors
    correct. find someone to scan it for you, or head down to your local autozone, advanced auto or whatever and have them scan it for free.
