Results 1 to 31 of 31
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Catch can update
    Well got my catch can back from having the filter flanges chaned from 1" to 2".
    Now I just have to order all the fittings and lines.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Catch can update
    How is this contained going to be cleaned? Looks like it will need to be removed.
    Feb 27 2005
    North Wales, PA
    you should get a flange welded on at the bottom so you can run a hose with a valve on it and run it downwards. When you want to drain it into a bucket, just open up the valve.
    Jul 07 2004
    socal
    Quote Originally Posted by nebone22 View Post
    at this time I just have it setup so that I just take it out which isn't hard since its held in with 1 bolt. If I want to add a drain I would have to change the design, but I could just take off 1 filter and use a vacuum setup to clean out the can.
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    that looks sweet man, i have a race battery and plan on going this route when i do my bt.
    ::2002 S6
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Sick. Thats what I need.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Damn. I need one too.
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    San Jose, CA
    nice set up mike. love the valve cover.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Sorry for being noob..but what exactly is a catch can, and what does it do? Is it some sort of filter?
    TEAM|AXION
    Veteran Member Four Rings diegomatrix's Avatar
    Jun 04 2005
    das auto
    collects oil vapours that condense from the pcv system so that that crude(water/oil mixture) doesn't get back into the crankcase and cause sludge problems.
    Feb 17 2005
    Sarasota, FL
    Why 4 AN connections? What all are you connecting to it?
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    Looks good Mike! Does it come in carbon fiber? .........
    When are you going to have this completed?
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Feb 15 2007
    marimont
    Are you runing the lines through the wall? Are you using -12 or -10?
    Established Member Two Rings 1hotA4's Avatar
    Apr 25 2008
    My little 2001 A4 2.0T
    Atlanta, Ga
    Quote Originally Posted by fred2ka4 View Post
    Look its Italian Chrome! LOL
    Actually how often should a catch can be cleaned out? And what should you clean it with?
    BetaAlphaTau Member #37
    "Opinions are like Assholes, everyone has one!"
    Jul 07 2004
    socal
    Quote Originally Posted by solowb5 View Post
    I sent this one up with -10 fittings and the fittings are done so that the lines will run thru the firewall right to the fittings. The next one I am having made which will hold a race battery will have the lines going into the side of the catch can not the front so that they can be ran around or thru a single opening in the firewall.
    Fred no it does not "yet" but I am sure you would end up having it overlayed in CF, you overlay WHORE.
    Feb 15 2007
    marimont
    Then why does 034 use a -12 on the valve cover and block breather? I think that is to big of a line to run in the spaces provided in these bays. I had a hard enough time runing my -10 setup
    Jul 07 2004
    socal
    Not sure, but you can buy those same fitting in -10 which is what I am ordering from Summit.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You can always reduce it to whatever size you want. You're not stuck with the -12.....
    -Doug
    Jul 07 2004
    socal
    Correct. Thats just the size of the adaptor 034 offers. There are adaptors with the same size thread that will have a -10 AN male on the other side.
    -10 AN Male to 3/ 4 in. NPT Male
    I wanted black but cant seem to find a 3/4 to -10 AN male in anything but blue, but since its for the block breather it doesn't matter to me since it cant be seen anyway.
    Male -10 AN to Male 1/ 2 in. NPT
    These are the adaptors I am ordering for my setup.
    I already made a long list of needed parts for my catch can setup that includes all the part #'s and prices.
    Nov 26 2005
    NM
    I like the blue on your car as it accents the color of your car.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Mike,
    Where are you sourcing all your fittings from? Using SS braided lines?
    -Doug
    Jul 07 2004
    socal
    Mike,
    From summit and yes I will be using 2 -10 braided lines.
    Yeah but the AN fittings all have red on them which I dont like. I have those fittings on my fuel system which is why I will be doing all black AN fittings for my catch can.
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    What are the demensions of the catch can?
    "You know you have a bad idea when Ford guys are making fun of you."
    Jul 07 2004
    socal
    Quote Originally Posted by chris164935 View Post
    Sits perfectly on the battery tray. It is a little wider and shorter then the stock battery.
    Senior Member Three Rings Mad_Audi's Avatar
    Mar 06 2006
    97 Amulet Red Audi A4 1.8T
    Greenville, NC
    slick setup man! start selling kits!
    Jul 07 2004
    socal
    Ok a few pics while working on doing the -10 lines and fittings.
    With 034 block breather installed
    VC breather and both -10 lines. AN fittings are just dirty from putting the lines together.
    The next catch can I get wont have the fittings on the front so only 1 hole will be needed to run the lines thru the battery wall.
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Mike your still finding ways to lose weight!!!! How many holes did you drill?? HAHA
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jul 07 2004
    socal
    Quote Originally Posted by quattro16 View Post
    4 plus a little extra lol. I guess I could just cut the whole wall out and be done with it.
    Established Member Two Rings STASIK A4's Avatar
    Sep 28 2004
    Audi A4 1.8 Turbo Quattro
    Melbourne Australia
    Yea you might aswelll just butcher the whole car up.... ;)
    "I don't intend to grow up there's no future in it"
    96 B5 A4 Quattro
    2.0l GT25 440HP powered by Autronic SM2 with CDI 750cc injectors Walbro intank Bosch 044 external fuel pumps
    B5 S4 6Spd Drive train, Porsche 996 Front brakes over S4 rotors, PWR Custom FMIC, PWR Custom Power Steering Cooler, PWR Custom Gear Box Cooler, Tilton Gear Box Cooler Pump Ect.....
    Drive Fast Drive Safe Never ending Modding
    Jul 07 2004
    socal
    Quote Originally Posted by STASIK A4 View Post
    Audi doesn't make Swiss cheese.
    Well it isn't like parts cant be replace, but then I dont ever see myself selling this car anyway. How many normal people are going to buy a 800+hp A4?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    That block breather adapter is money! I can't wait until mine arrives. The valve cover looks CLEAN! I need to send mine to them and have 'em paint it and put the fitting on the back.
    Looking good!
    -Doug
