You want to check to see if your valve cover has the baffle in that spot where you want to tap for a line. If not you can always buy a 2001 valve cover since it will have the baffle.
For a dual inlet catch can, 034 sells one but it is not baffled and you can also find some on summit racing. If your looking to run a race battery in the stock spot I am having a catch can that will bolt into the stock battery spot that will also house a race battery. It will be baffled with 2 filters and 2 -10 inlets. Once its done I will post up pics. Nice part is that it will sit higher then the engine which is where it really needs to be.
It will look like this but instead of the whole thing being a catch can, just a L section will be catch can while the other spot will hold the race battery. The -10 fittings will be on the left side with the 2 filters on top. I will offer these cans to people that want them.
I also plan on trying this can with vented lines to the down pipe with 1 way valves instead of filters.
