Results 1 to 4 of 4
Thread: Need Help
    Senior Member Three Rings Alex818's Avatar
    Apr 17 2008
    RS6'd S4
    Hollywood, CA
    Need Help
    Hey guys
    i had a evo intake on my 2001 a4 avant and it was running great. but i had to get the car smogged so i put the OEM one back on and now it idles really rough. i checked the sensors and everything looks fine. the car almost stalls if left on. what the hell did i to wrong?
    thx
    Alex
    Apr 17 2008
    RS6'd S4
    Hollywood, CA
    Re: Need Help
    and now the check engine light is on...
    Apr 17 2008
    RS6'd S4
    Hollywood, CA
    Re: Need Help
    bump
    i've tried everything. has anyone ran in to this kind of problem?
    any response would help
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Need Help
    Try a throttle body adaptation. Turn the key to the on position without starting the car. Let it sit for a minute or two and then start the car. That may help.
    You may have a loose vac line somewhere which could cause a rough stumbly idle.
    Jim
    I Do Werk.
