Results 1 to 17 of 17
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Ram Air headlight is in and driven:
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Registered Member Three Rings Charlie's Avatar
    Sep 16 2006
    West Haven CT
    Re: Ram Air headlight is in and driven:
    any increases noticed?
    |Stage 2+ B5 S4|
    FOR SALE
    Registered Member Three Rings Clay @ Kinetic's Avatar
    Jun 11 2004
    01.5 Imola S4 Stage 3++...
    Surrey, BC
    Niiiiiiiiiiiiiiiiiiice
    Clay Marshall (AKA: rippinralf)
    Kinetic Motorsport
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Sexy Times.......
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Wow, he cut in to e-codes.
    Looks good. Wouldn't that screw up the headlights, having them opened like that, fogging and such?
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Senior Member Two Rings hachirokukid's Avatar
    Mar 22 2007
    00 S4, 07 A4 2.0t
    nc
    looks alright...wonder if it made any power difference...
    Veteran Member Four Rings damnthemansam's Avatar
    Sep 20 2006
    motorcycles, boats, other cars and a longboard
    san jose, ca
    i would have put a piece of pvc pipe inside the headlight..
    Jun 05 2007
    San Jose, CA
    I think he did put a tube inside the headlight it's just a transparent plastic tube i believe. Look carefully on pic #2 and 6.
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    Not much of a ram effect; that inlet is small. I have a feeling any gains are placebos because everything still gets compressed at the same psi in the end.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    I personally think its ugly.... To each their own.. Good luck, Gains are probably very minor ..
    Dec 10 2006
    Wisconsin
    Quote Originally Posted by Rated S View Post
    My ecode was f-d up from the get-go due to a dishonest seller who sent me a pic of a new ecode instead of the "chrome chipping" one he sent me. I had little to lose on this experiment.
    It does feel different. Plecabo, maybe, but it seemed to quiet down my car a little (clutch fan is removed so it was quiet to start).
    It also feels like it pulls strong earlier on. Again, placebo maybe but it felt different to me. Like going from piggies to DP's. Minimal, but slightly noticable.
    The lights will eventually be all sealed and water/air tight so they don't fog up. I won't do this until I can see the actual performance #'s. Dyno time.
    Wings
    Carbs
    Titaniums
    Dec 10 2006
    Wisconsin
    Quote Originally Posted by SilverSurferS4 View Post
    No doubt the Black Bezel gives it away a bit sooner. This was the easiest solution to start out. I may move to a clear connector bezel to seal the clear tube to the clear lens. This would make it much more stealthy. I just have to find the best way. Asthetics come after performance testing.
    Wings
    Carbs
    Titaniums
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    thumb up for doing it, but your really not gaining much of anything... looking for colder air?? the turbos compress the air and make it hot anyway, not to mention all that intake plumbing running on top and beside the engine are just adding to the heating effect.
    you might could say the extra air being forced into the airbox helps spool time, but dear god the turbos on these cars spool at idle lol.
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Props on doing it yourself, but i dont think youll see any big gains from it. On a cool night while at speed on the highway im sure youll be able to tell a little difference(mainly because of air density, not just temp)...but while putting around town the benefits will be negligable. If you were to run a velocity stack and bypass the airbox you would see much better gains...if it doesnt throw a code for the MAF(another reason that i dislike mafs lol). Also, i know its ugly, but the optimal place for the velocity stack would be 2-3" out from the headlight. While at speed, pressure will build up on the front of the car and actually create a boundry of "dead air" on the surface of the bumper. For optimal performance, the VS would have to be outside of that barrier. This is why you see so many SFWD/SRWD drag cars with stacks sticking out from the headlight.
    Im not knocking it at all...just giving my opinion. Once again, i give you props for doing this yourself!
    BTW-Unless you were able to exactly reproduce the conditions seen at speed on the highway you wont see any gains on the dyno. This is something that would be better tested through logging and before/after times at the track.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Nov 09 2007
    Track Whore, CA
    Quote Originally Posted by s vier View Post
    Definitely placebo. If it pulls strong "earlier" it's all in your head, as the ram-air wouldn't have any effect earlier, only at high speeds, if any.
    '00 B5S4 - Sold
    Good USA
    Veteran Member Three Rings ToMMyRsK04's Avatar
    Dec 26 2006
    2000 audi s4
    New York
    If you type in EVODAVE in google and click whatever comes up .. you'll see his work .. does crazy work for headlights and taillights .. the ducts look really good for the headlight mod
    bye bye AWE Stg 3+ and HeLLooOo ........
    For Sale
    - VAST Port & Polished Intake Manifold - BEST OFFER
    - Stock B5 S4Pistons/Rods/Valves/Springs/Retainers/Cams 44k on them
    - Two GT3076 Turbos
    Oct 30 2007
    Pasadena, MD
    If I sent you my headlight how much would you charge to do just the headlight portion?
