Results 1 to 7 of 7
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Owner of a 03 Audi A4 3.0 - HID FOG HELP
    Bought Fogs for my car had a dude try to put them on right. Well we tried that and turned them on they would stay on for 3 secs then turn its self off. we then bough low voltage relays for the car. that didnt do anything. The best that we could do was get one fog light to work on One side. Does any one know anything about the electrical system on an Audi and Why these Fogs wont work properly. (it wasnt the kit cause we plug them out, outside of the car and it worked)
    Established Member Two Rings sunthose80's Avatar
    Jul 25 2007
    Re: Owner of a 03 Audi A4 3.0 - HID FOG HELP
    water in the housing? touched the bulbs? short near the area you are intalling them oc connecting them?
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    No water, Bulb was kept in pastic mini containiner, Could be a short no clue. he's working on it as wee speak
    Established Member Two Rings bavaria75's Avatar
    Feb 13 2008
    02 A4 3.0QM - 04 Passat 1.8TM
    San Jose, CA
    Hmm, I guess if the computer would switch them off after 3 sec automaticly there most be a reason and you might find a error code on the cluster or vag-com???
    Maybe this helps you:
    http://www.ross-tech.com/vag-com/cars/audiB6.html
    2002 A4 3.0 Quattro Manual
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    the guy got it to work......the only thing is the the dash board is saying that the fog lights dont work...what do i do? the guy said sumthing with a relay or a harness...Help
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    What bulbs are you using? And make sure you ask him what exactly he did. I rather use OE wiring, maybe relays? Thankfully my HIDs didn't require any.
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    this has been talked over before... mine did the same thing..... certain kit's cause our car's computer to be a dick, and turn one or both bulbs off after few seconds... why - nobody has any idea... maybe too much/too little power drain.... But VVME H11 hid kit proved (in many cases) to work good... so I just ended up getting that.... as for getting relays and what not to make their troubling kit work - I don't know anyone yet... Good luck!
