Results 1 to 13 of 13
    Registered Member Two Rings Miah88's Avatar
    Dec 25 2007
    Iowa
    ??buying an audi??
    Im looking at buying a '99 audi a6 2.8 quattro with 115,000 mi. what are some things I'll should look for and some info I should find out about it before buying? any feedback will help thanks!
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Re: ??buying an audi??
    Forget 2.8 -- look for a 2.7t
    wofman
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Dec 25 2007
    Iowa
    thank you....but thats not an option right now. A little more input would be nice
    Sep 12 2007
    at that mileage, I would make sure that the timing belt and water pump have been replaced - i think audi recommends that around 100k for the 2.8.
    out of curiosity, why is a 2.7T out of the question?
    Sep 12 2007
    also, i am not sure if the 2.8 V6 in the A6 is the same as the 2.8 that was found in the a4, GTI, jetta (vr6), but if so you could check with people that have those cars for other common errors with the engine.
    Dec 25 2007
    Iowa
    well I live in iowa and we buy what ever we can get here cause not much comes through. plus, I need a car like yesterday and i know the guy whos dad owns the car lot so im getting a good deal on it
    Sep 12 2007
    yeah that makes sense. well good luck with it at any rate. sorry i couldn't help more (i drive a GTI).
    Sep 20 2006
    Burnaby, BC, Canada
    2.8 don't seem to have many problems, just as long as timing belt is done it should be fine... check that all the electrics work and you should be good to go
    Registered Member Three Rings m-avant's Avatar
    Aug 05 2007
    cars with wheels...
    Californication
    If you can find an Audi independent shop that can perform a pre-purchase inspection - you should have one done. The PPI should be able to spot "trouble areas".
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    old Avant (missed dearly) :2000 A4
    Apr 01 2008
    2010 Jetta TDI
    A deal is a deal, I guess... Near Chicago? Check CraigsList? Comfy ride, but I'd only deal with maintenance of Audi if I had performance of 2.7+.
    Established Member Two Rings Snowhere's Avatar
    Mar 20 2008
    2001 A6Q Avant, 90 G60 Corrado
    Buena Vista Colorado
    Camshaft seals, serpentine belt tensioner, valve cover gasket, tie-rods are all items that should be checked. The seals and gasket are the common sources of oil leaks. Like said above, the timing belt and water pump should have already been replaced, and a lot of the little stuff should of been taken care of at the same time. The tie-rod design was updated at some point, and it is always good to see the newer version on the car.
    The 2.8 may be slower then the 2.7T, but it is not terrible. I have the heavier Avant and it is no rocket off the line, but I have no trouble with the passing power. Since most of my driving is on lightly traveled roads, I wanted the reliability of the 2.8 over the 2.7T. On my daily commute of 37 miles each way, I might see 5 to 10 other cars until I get close to my work. And of the cars I do catch up to, I have no problem passing them, even at 9 to 10,000 ft above sealevel.
    When the turbos go on the 2.7, and they will go, you are looking at big $ to replace both of them. And since you have to drop both the engine and the tranny to replace one, you might as well replace both.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Snowhere drops knowledge son. You might wanna check out the 12v/30v (whichever it is )forum over on audiworld.com
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Dec 25 2007
    Iowa
    thanks a lot guys!
