Results 1 to 6 of 6
    Apr 14 2008
    Cali. CAN
    I think I hear a dying fuel pump ?
    Hey Guys, .
    Sometimes.....when I turn my car on, I can hear some kind of fluid sucking or slurping noise coming from the rear. I can only hear it for 3-5 seconds and then it goes away, someday I don't hear it at all.
    The first thing I think of is the fuel pump ?
    Could it be anything else ?
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Re: I think I hear a dying fuel pump ?
    Its probably the smaller pump that pumps the fuel over the hump in the tank that you can hear. I think its common to be able to hear it sometimes
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Is this with the car running or just with the key on? Because the pump only turns on for 3-5 seconds when you first turn the key to the on position, then the pump turns off and doesn't come back on again till the car is started. It only comes on for that short period of time so it can pressurize the fuel lines. This is way its always good to turn the key on for those few seconds before staring the engine.
    Apr 14 2008
    Cali. CAN
    I'll have to check, I've only heard the noise after I've turned the engine on.
    Apr 14 2008
    Cali. CAN
    Quote Originally Posted by Mawhitey View Post
    it is only sometimes....are you saying I shouldn't worry about it ?
    Jul 07 2004
    socal
    Quote Originally Posted by Sen sen View Post
    It isn't an issue with your fuel pump, if it was then your car wouldn't run at all because the fuel pump is either going to be working or its going to be dead and there is no such thing as a "dying" fuel pump.
