Results 1 to 6 of 6
    Established Member Two Rings Asimko's Avatar
    Apr 26 2008
    Help Possible Dealer Screw Up
    I just bought an 06 A4 S-Line and part of the deal was the dealer would install the xm tuner. Does anyone know how the xm would function if this cable was not switched? I recieve about 4 stations, but everytime I call xm to program it the unit never picks up the new stations. I know the antenna works because I can listen to the preview stations I just cant get it programed. My dealer is an hour away so I would rather not drive there to have them fix it. I used to do this stuff for a living so I im not worried about fixing it myself just looking for a little insight. I have no access to the car right now because I am at work and it may rain later, so who knows when I can take a look. If its the cable it would be great but if not its most likely the tuner and off to the dealer I go. Any assistence would be greatly appreciated. Thank you
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    Re: Help Possible Dealer Screw Up
    don't you have to call a number first to activate the other channels?
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Apr 26 2008
    I did that a total of about 10 times and had the car in a different location each time but no luck. XM told me that a last resort they would send a stronger signal and see if that helped, but yet a gain nothing. Dealer said to bring it in but just didnt know if anyone had any ideas or had the same issue.
    Senior Member Two Rings Quigaboo's Avatar
    Jan 10 2008
    2008 A4 2.0t Quattro
    Bellmore, NY
    If you switch that cable you will probably get NO channels at all. You can give it a shot but i doubt it will work. Might have a bad receiver. !
    Veteran Member Four Rings A4_cabrio's Avatar
    Aug 09 2004
    2005.5 A4 2.0T
    Austin, TX
    Hid you leave the receiver connected long enough for the data to be downloaded?
    It took me a great time before my receiver linked up and got all the channels.
    Did you use the right serial number?
    As long as you receive channels - you are fine cables/connections(wise).
    2005.5 2.0T Tip Dolphin Grey / Black Interior
    Factory options: all except for Bose sound
    Added: 35% Tint, OEM Bluetooth, MFSW with paddle shifters, RS4 pedals, Brushed Aluminium mirror caps, S-line bumper, RS4 grille, Euro plate filler, 19" RS4 reps (Velocity), S4 valence, Satellite receiver, Quad tips, VMR boost gauge, AUX port
    Next mods: honeycomb fog grilles, LED DRL, Dension
    Apr 26 2008
    Yes I left the receiver on for 3-4hrs each time when they attempted to send the signal. I thought of the wrong serial # because there was a 0 that i thought might have been an O but they ruled that out over at XM. From what A4 Cabrio said it sounds like a bad receiver. I even tried unpluging the receiver and so it would reset but that didnt work either. Thanks for the help I may still look at the cable but looks like im going to the dealer.
