Ok, I am trying to wire an AVH-P4000DVD into my car. I used the metra wiring kit that Crutchfield provides for our cars. It is also the one many people have on these forums have used to install an Avic D3.
Here is a picture of the metra harness soldered to the pioneer harness:
The connection I made are the following:
Pioneer YELLOW wire (constant 12V)
Metra YELLOW wire (constant 12V) on black harness
Pioneer Red wire (12 volts switched)
Metra RED wire(12 volts switched) on black harness
Pioneer ORANGE/WHITE wire (Connect to lighting swich terminal)
Metra ORANGE wire(Illumination) on black harness
Pioneer BLACK wire (Chassis ground)
Metra BLACK wire(Chassis ground) on black harness
Pioneer BLUE/WHITE wire (To system control terminal of the power amp)
Metra BLUE/WHITE wire(Amplifier Turn-On) on red harness
Metra GRAY RCA (Right Front AMP Imput) on red harness
Pioneer FR terminal
Metra WHITE RCA (Left Front AMP Input) on red harness
Pioneer FL terminal
Metra GREED RCA (Left Rear AMP Input) on red harness
Pioneer RL terminal
Metra VIOLET RCA (Right Rear AMP Input) on red harness
Pioneer RR terminal
Metra BLUE wire (Powe Antenna) on black harness
Metra BLUE wire (Antenna Amplification) on EU to USA antenna converting harness
Now, the unit powes up just fine and plays cds but there is no sound coming from the speakers. The bose amp in the trunk is good because it works with the stock Symphony headunit.. same goes for the speakers. Does anyone have any insisght into this? Again, the problem is NO SOUND...
The light green wire is not hookes up yet as this is not needed to test the sound.
