Results 1 to 19 of 19
    Dec 26 2007
    SF Bay Area
    installing new ECU?!? @#$*&(@*#&$!!!!
    Ok folks, I'm trying to swap out my ECU with an APR I picked up quite a while back.
    I have looked thru the forums, APRs DIY article, and this http://www.audiworld.com/tech/eng4.shtml .
    But, how the @WR&*@(#*$&(*@#$*&YFUI(*&*(@# do you remove that last bolt in the back!? I don't want to have to take the whole cowel apart, is there an easier way? I have a '99.5, and while the outline for that "pop-out" is there, mine does not pop out!
    I can't believe how they designed this car!!!
    Anyone have any tips or insight?! Do I need a mini rachet that is 1/4" thick and a socket that is just as small!?
    Veteran Member Four Rings goody6691's Avatar
    Feb 23 2005
    Elkton Md, B.A.T certified
    Re: installing new ECU?!? @#$*&(@*#&$!!!!
    Yes
    too much shit to list
    Dave
    it runs bitches..............im back
    98.5,Brilliant Yellow, Audi ,A4,Quattro, 2.0, je, eagle, cat cams, tial, hta3076r, tap 630, CCW Classics, Falken,SPA, Autopower, Sparco
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    From the article:
    You can remove 4 of the 5 bolts fairly easily at this point with an 8mm socket. The fifth & last screw is hidden by the aforementioned black wiper fairing. If you don't have the access port plug, you will have to get at it from outside the hood. I dug my fingers in between the fairing and the windshield glass to see the 5th screw. Using a long extension, I loosened the screw several turns, then finished the job by relaxing the fairing, then reaching back under the hood, over the ECU box, and pulling the screw out. You do not want to drop this screw, as it would be a devil of a time getting it back.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    its like a 10 minute process man.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Senior Member Two Rings BigA1.8T's Avatar
    Mar 12 2007
    2000 A4 1.8TQM
    Milton NH
    Quote Originally Posted by Stampy View Post
    my thoughts exactly
    APR Tuned|Custom Intake|Bailey Motor Sport DV|10K HID|2.5 Custom Magnaflow Exhaust|Smoked turn signals|Debadged|Custom Vent Boost Gauge|Polished Intake Manifold|Neuspeed Race Springs. More in the works...
    Sep 17 2006
    07 cbr600
    and just leave it out once you have it out.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    If you ride the short bus It's called 8mm and you can use a ratchet or a wrench or.....wait wait....wait one sec more yup a ratcheting wrench.
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    This is what I used from Sears
    2014 A4Q Red w/ black optic black interior
    Aug 19 2007
    central oregon
    its good to have small hands...
    Established Member Two Rings jonrogers42's Avatar
    Dec 30 2007
    Indiana
    put some elbow grease into it!
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    I broke it!!!!!!fuck that screw. no problems whatsoever.
    I have no patiense!!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    It's not that hard, you don't even have to take the cowl off completely.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    lol, just get some vice grips or something!
    I just used a wrench
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 26 2007
    SF Bay Area
    I'll try a crescent wrench...it'll take a while..but I don't plan to put that screw back in!
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    It will come out with a bit of a squeeze and an 8mm spanner, or 1/4 in dr 8mm socket. It took you longer to post on here than it would to remove,lol j/k
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Oct 30 2006
    B8 A4 Avant 6spd
    Ah cmon man, that last screw is cake, just need a small 8 on a small ratchet and it fits no problem.
    -18 718 GTS
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by pipe7284 View Post
    back away from the car.
    do it right or dont do it at all.
    Veteran Member Three Rings beejohn's Avatar
    Jan 24 2005
    Pennsylvania
    wow. it really is not that hard to remove the windshield wipers which is what i do. 10mm nuts, and two phillips screws.
    take your time with mods. ^^^ what modified said, "do it right or don't do it at all". yeah it's just a screw, but in the future...
    --beejohn
    2001 A4 1.8TQMS
    Jan 20 2005
    99 AJL TQS
    UK
    I wish your ECU's would work on my car, you have better tunes available over there
    -Mark -
