Results 1 to 11 of 11
    Veteran Member Three Rings chimchongdlight's Avatar
    Jan 02 2007
    Bay Area to Sacramento Ca
    FMIC install question
    ok so couple question, i finished the install, looks great behind the s4 bumper, ne ways
    questions:
    1. i used the stock hose from the turbo and the manifold right, now u know the hose on the passenger side that u take off, do i have to cover that with something? or do i just leave it like that? same thing on the driver side, when i go and pull off the hose from the stock intercooler, one of the hoses i used for the FMIC, but the bottom hose is the problem, what do i do with that open hole?
    2. i get a CEL, is that normal? i get two codes actually one code is p0303 and the other is p0303pd. i know it what the p0303 is, its mis fire on number three correct? well i fixed that recently, and the CEL disapeared, and now that i have installed the FMIC its back, and it says that the second code p0303pd, why is it pending, what does this mean?
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Re: FMIC install question
    1- if your talking about the "pipe" that was used for the stock smic that the snub mount bolts to then, yes you just keep it open
    2- cel is not normal, just clear it and see if it coms back
    and gj on installing it yourself and saving money
    EDIT- btw what fmic did you get
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Jan 02 2007
    what do u mean its not normal, how do i clear the CEL? i know how to read them but dont know how to clear them
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by chimchongdlight View Post
    Hit the clear button on the same page that you are looking at the codes with if your using a VAGcom.
    Jan 02 2007
    nah wasn't using a vagcom, just using an obdII reader
    what do u guys think is wrong? why do u think i have a CEL? and why is it pending?
    Veteran Member Four Rings savetheclutch's Avatar
    Oct 01 2006
    ducatis and a miata
    Fort Lee, NJ
    could be a leak, I did not bolt one of my hoses right and it was throwing a cel.
    Aug 16 2007
    Buffalo NY
    pics?
    Jan 02 2007
    pics will be up soon, a leak hu, i tightened everything up with a drill and 8mm socket, so i dont think theres a leak, i was just driving around and i didnt have ne problems with it at all
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    you should be able to clear codes with your obd11 reader, maybe unplug your battery for 10min will clear it(works with obd1 cars)
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Check for spark plug issues
    Jan 02 2007
    ok so let me update, i drove it a little tonight, even with the CEL, figured nothing is wrong, through out the day its still on, then it turned off on its own, i think its ok, the car isn't feeling like its dying or nething like that, it feels great, i think i even feel a difference., pics will be up soon, its nothing to really look at, the car is a work in progress
