Results 1 to 19 of 19
    Veteran Member Four Rings alen's Avatar
    May 11 2004
    1.8tqms
    ghettlanta
    Is it possible to adjust headlight projectors from side to side?
    I got a HID kit for my stock projectors and it seems like they are pointing sideways more than straight. Is it possible to adjust them from side to side?
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Re: Is it possible to adjust headlight projectors from side to side?
    Yes on of the screws on each headlight is for up/down and the other is for right/left. I forget which one is which, but it shouldn't be too hard to figure out.
    ~Brian
    1998.5 A4 2.8QT
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I believe the outside screw is for left/right. Inside is for up/down.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    Try this,
    Go somewhere where you can drive up real close to a wall, but still back up about 20 feet.
    Go at night. Drive as close to the wall as possible and mark (with masking tape or whatever) where the lights are pointing. Then drive straight back about 20 feet and aim the center of the beam 2" to the right and 2" down from the mark.
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Quote Originally Posted by whoace View Post
    Try this,
    how well does this work for "calibrating" the beams?
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Dec 05 2007
    Quote Originally Posted by Stampy View Post
    Correct.
    Quote Originally Posted by Jared71482 View Post
    The inner adjusters control the up and down... outers adjust the side to side.
    Left (driver side) headlight: turn the outer adjuster clockwise to move the beam to the right... counterclockwise to move the beam left (as if you were sitting in the car)
    Turn the inner adjuster clockwise to go down... counterclockwise to go up.
    Right (passenger side) headlight: turn the outer adjuster clockwise to move the beam left... counterclockwise to move the beam right (as if you were sitting in the car)
    Inner adjuster is the same as the driver side headlight.
    Mar 07 2014
    I think I did an adjustment that went too far and I heard something click. Now I don't see any movement, is the headlights damaged, and what is the fix?
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Quote Originally Posted by LegendaryT2 View Post
    Two possible outcomes, the plastic ball has popped out of the socket or the adjuster mechanism is broken; you went too far.
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I did this with my Depot ecodes, the adjustment screw has a little ball that pulls out of the projector assembly. Take the headlight out, and push it back in by hand.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Mar 07 2014
    Quote Originally Posted by Avant Nate View Post
    Do I have to take out the headlight or just the bulbs... And with that being said, if the adjustment range isn't going to where it would be sufficient, how do I get it to a good aim?
    Nov 04 2012
    Reno
    I did this with mine and it broke, horribly.
    Dec 23 2009
    Boulder, CO
    I took the headlight out, because you have to stick your hand in through the back to snap it back in. As far as aiming it, I was more careful the second time.
    Mar 07 2014
    I'm.starting to get tired taking off this bumper lol
    Nov 04 2012
    Reno
    You don't have to take off the bumper to get the headlights off.
    Mar 07 2014
    Quote Originally Posted by RENOxDECEPTION View Post
    U mean to tell me all this time I been doing this the long way?? All this time I'm dragging myself under this car. R u sure ur referring to taking out the assembly or jus the bulbs?
    Nov 04 2012
    Reno
    I'm referring to taking one piece headlights out of a 2000 audi a4 b5.
    I'm not sure about 2 piece headlights, but one piece you can get out without removing anything.
    Be careful please, I don't want to be responsible when you break tabs on the headlights.
    Mar 07 2014
    Any way to explain cuz I know at least I would have to disconnect the bumper from the fender and push down... Maybe that. Otherwise do u have a pic of this ball that I have to push back in so I know what I would be looking for?
    Mar 07 2014
    I'm not sure if HID and non HID are different. But I took a peek at my non HID lights to see if I can spot this ball or anything out of order. I had no luck in spotting any ball of anything and I dont want to take out the HID ones only to get stumped again.
    Nov 06 2013
    Melbourne, Australia
    Mine can be adjust up and down but not side to side ....... :(, i think the ball for the side adjustment has popped out.
