Results 1 to 11 of 11
    Jan 31 2008
    Grafton, WI
    Test Pipe question...(not on choosing it)
    Guys,
    What exactly is the test pipe for? Besides throwing the CEL
    2005 Infiniti G35 RWD, 6spd Manual, Sport Package
    2002 Audi A4 Quattro, 5 spd. [SOLD]
    Jun 30 2007
    Raleigh, NC
    Re: Test Pipe question...(not on choosing it)
    better spool, more torque down low, eliminates the restriction in your exhaust known as the "catalytic converter"
    and personally, it's my way of taking revenge on atleast one or two hybrids...
    for every hybrid on the road -- someone should run a TP!
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jan 31 2008
    Grafton, WI
    haha thanks man. Does it make noticeable difference if you are bone stock besides a new DV? Or is it only good when some engine mods/chipping is in place?
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    I would recommend it if you have an aftermarket exhaust, but with stock exhaust its a waste IMO.
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Jun 30 2007
    Raleigh, NC
    i noticed a difference for sure. I lost some pull up top, but i definitely picked up some down low. I dyno'd 113awhp and 137awtq with nothing but the exhaust, DV, and a cone filter on my intake.
    The Awesome™
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Max, you gotta get an exhaust now, i can hook you up with a cool place, but it is close to Chicago though. And you can isntall yout TestPipe there. I'm thinking about TP, but i dont wanna have problems with our emissions. But will i?
    Cause ifrom what i understand, lets say Revo Stage 2 just takes the cell off of you instrument cluster, but u stil can see it when you VAG or use OBD at emissions, am i wrong???
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Jun 30 2007
    Raleigh, NC
    i'm pretty sure that revo2 gets rid of it all together. and if it helps -- i passed emissions testing with my test pipe. anti-foulers, and reset the ECU right before you go. it won't scan for readiness or check the 02 as long as you don't drive for more than like, 30 mins at 35mph or something like that. (there are intervals at which the ECU checks to see if anything is wrong, and i can't remember them.) as long as you drive straight there you should be fine.
    The Awesome™
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    Quote Originally Posted by B6Lovin View Post
    part throttle cruise is when the ECU checks readiness....including the rear o2 cat efficiency test...an example of this would be steady throttle in a gear where the car is running a hair under 3k rpm...then the test will initiate and fail readiness/cat efficency.
    i have taken a number of cars to emissions having just cleared codes...the problem is that fuel trims also reset which can effect emissions. block 032 in VAG-COM (basic settings) will trim fuel quickly at part throttle...so i always drove just a few miles to steady out trims then went (after clearning codes). laptop and VAG cable in car while in the testing center too.....hehehehe
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Jan 31 2008
    Grafton, WI
    lol, ^^^^nice.
    I already have a sweet deal on a custom exhaust system, trying to come up with cash now. I'm not planning on getting a test pipe until I get chipped. Just did not know the purpose of it.
    Jun 30 2007
    Raleigh, NC
    hahaha, glad to know i'm not the only one - and thanks for clearing that up. I know my CEL never comes on in stop-n-go traffic, just on the highway and longer periods cruising in the city.
    The Awesome™
    Buncha motorcycles
    Memphis, TN
    i have APR 1+ and just asked for the Test pipe file and i never have a CEL from it
    APR Stage 2/AWE Intake
