Anytime you deal with porting of intake or exhaust components, you should keep in mind that the airflow through this device will be relative to throttle response and/or lag. If you have a large turbo setup and the intake manifold is a limiting factor, you could possibly reap a fair amount of top end flow from some port work.
For a K03 powered car, I personally would keep the stock intake manifold so that the turbos would spool quickly. Opening the ports will create a bottleneck (when it funnels down into the heads) and slow airflow as it hits the bottleneck. You would effectively increase lag in a trade for top end flow. The problem here is that the K03 has no top end flow. After 5K RPMs the K03 are on the downslope.
Also, for a car driven on the street, it would be much more enjoyable to have the quick boost response to zip through the gears around town. If your car was a drag car or used on a road course, you would make better use of the top end flow (also considering you had larger turbos to make that additional airflow at the upper RPMs).
