Results 1 to 40 of 79
    Senior Member Two Rings p.tony's Avatar
    Sep 02 2007
    2000 s4 Stage 3, 1997 Lexus sc300 na-t, 2004 Touareg v8, 2007 Corvette
    Baltimore, MD
    Vast Intake Manifold
    Wanted to know if anyone is a testament to the performance factor of the ported and polished intake. Was thinking about doing it but wanted a first hand review. Thanks for your input
    00 C5 2.7t //Stage 3//
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Re: Vast Intake Manifold
    Id be interested in knowing as well. It will definitely work better than stock if it was done right, and im sure Vast would do it right. The only thing that concerns me is the fact that the stock manifold uses velocity stacks at the entrance of each port. This is great for flow, but changing the radius of velocity stacks can cause some loss of velocity which would change throttle response at lower engine speeds. It could also cause reverb inside the manifold at higher engine speeds, but i dont think you could take off enough material on the stocker to cause this...especially on the stock cams.
    As i said, im sure Vast knows what theyre doing and wouldnt release a product that didnt improve power. Im still really interested in finding out how they perform.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    how much does it cost $?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    treefiddy
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    which VAST Intake Mani?
    is it the OEM manifold w PnP? the gains are insignificant. there is not much you can do cept for remove the castings. this will help with flow characteristics... but almost not at all. if its the SPTurks mani, then different story.
    that is all.
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Quote Originally Posted by MiniRS4 View Post
    that is all.
    Actually theres a lot you can do to the stocker, if you look inside one you will see the bells r in horrible shape from the factory not to mention the throttle body opening is blocked about 10-15%...
    Aug 11 2005
    Quote Originally Posted by generationjdm View Post
    like i said, you can remove the castings... even in around the bell. maybe open them up a lil. TB too... but what do you think that is going to yield?
    i know itll do something. every lil bit helps. but alone, the PnP wont do much. not anything significant anyways. i say skip on the VAST Intake Mani.
    on the other hand, if you want to see some gains/difference, SPTurks Mani FTW. PM me if you are interested. cheers, that is all.
    Dec 20 2005
    District 7
    what does the spurks manifold do different?
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    I noticed the car to be much much smoother in acceleration...I also added the phenolic spacers so that helped also, I recommend it. The only serious benefit on the butt dyno would be the rs4 or 2.8 heads with cams and a bigger plenum like the sp turks version. But for a couple hundred bucks I can't complain
    Aug 11 2005
    Quote Originally Posted by revhards4 View Post
    bet it wasnt the intake mani, rather the Phenolics! phenolics FTW!
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    ok if your gonna pimp the spturks mani, you gotta give us more info. ive seen the pics ... and i applaud the effort. what kind of gains are seen? any logs? what other mods are/should be done?
    the thing is, these cars are boosted, so what does the extra plenum space really do? what kind of design considerations were put into it? just a 'make it bigger' approach?
    im very curious about all the intake mod stuff and wish we could do more scientific testing to see the effects of rs4 cams, bigger intake manifolds, bigger bipipes, bigger inlet pipes to turbos ... data data data
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Sep 02 2007
    Baltimore, MD
    I posted the same question in tha A6 section of the forum. Daft the moderator gave a pretty good answer to the question posed. Check it out
    Mar 14 2007
    michigan
    Quote Originally Posted by DxC View Post
    If theres any gains I would guess they will be seen well into the 7k rpm range...
    Feb 14 2004
    Michigan
    Just like on the Honda B-series engines...the edelbrock intake manifolds made 30 extra wheel horsepower and held the torque better through out the entire rpm range...I can only assume that with a bigger plenum on the s4 would act in the same fashion.
    Feb 17 2004
    Sterling, VA
    I agree with this but, this is where you'd want to have a larger turbo on your car. As we all know, the K03's demise begins at 5Krpms.....
    My opinion is to keep the stock intake manifold if you have K03s. If you have more top end airflow then, you can take advantage of the intake manifold & throttle body mods.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    However if the s4 manifold was built much better than the stock honda b series then the gains would yeild different results. Its kind of like saying, well the honda picked up 4whp with an open element filter but the audi lost 1whp with an open element filter. Maybe the factory airbox on the honda was a bad design compared to the factory audi airbox. Its all here-say.
    Nov 16 2006
    Boston
    the honda was NA right? the s4 is turbo ... air in the intake manifold is already pressurized ... so its pretty much getting shoved into the combustion chamber already ...
    1999 Black A4 Avant
    Aug 11 2005
    D,
    looks like you need to flip one and get on your computer and do a lil HW, lol. extra plenum- what does it do? are you serious? you obviously know what the intake mani does. what do you think will happen when you increase the volume of the plenum then? it will obviously allow for more air. (look up enlarged intake mani/plenums for other turbo cars!)
    i cannot go into specifics regarding the design etc, but i can assure you that there was plenty of RnD that went into the design- few revisions. after all, you dont want it to be too big, then it will work against you.
    as for logs, data, etc... im not a data/logger whore, so i dont have anything for you, but i know that others have logged, and they have seen a dramatic difference in air flow. Kurt@VAST has been logging it and cannot believe the results. i also had a special version w a larger throttle body on my KO4s and you can definitely feel the difference.
    to sum up what it will do for you... on a KO4 car, after you boost, it hits hard, but then slowly tapers off. you can feel the car dying off to the redline. w the SPTurks mani you dont feel the car being choked off. rather, the tach still keeps flying. in fact if you dont pay attention, the ****** will just bounce off the limiter.
    here is a vid of the SPTurks Manifold in action. granted Greg's and my car werent running quite right, but look at how out he is... whew!
    SPTURKS MANIFOLD VIDEO - (3) SSP Tuned STAGE III RACE
    i hope i have answered your questions. the last few things ill mention is that you'll need phenolic spacers for this mod (which i have for sale), and also that the Black Beast (SPTurks car) is for sale. PM me for both, and until next time, cheers...
    that is all.
    Aug 11 2005
    the SPT Mani provides additional air all the way through the rev band. the gains are seen well before 7k, lol. at 7k its already game over- no more to rev... what are you talking about?
    anyhow... if you meant that the gains might be felt more in the high-end of the rev then you are more or less right. more air and not being choked off ='s extra powa. that is all.
    Senior Member Two Rings hachirokukid's Avatar
    Mar 22 2007
    00 S4, 07 A4 2.0t
    nc
    anyone got pics of this SPTurks Mani? i never seen one...
    Mar 14 2007
    michigan
    Lets see the logs over the stock mani and the rs4 mani? Whats on Gregs GT car? "My guess would be that the larger plenum would benefit more upstairs as they always do" is what i said
    Nov 16 2006
    Boston
    hey minirs4, ur right, ill look up the role a larger plenum plays in other turbo cars. im sure theres much more info for some turbo nissans/supras so ill read up. i was just thinking that since the air in the intake mani is pressurized, there would already be more than enough air for the combustion chamber.
    im skeptical for now just because there isnt much information on anything, but i really do hope that an enlarged plenum (maybe combined with 2.8 heads and rs4 cams) has a significant increase in power :)
    "i cannot go into specifics regarding the design etc, but i can assure you that there was plenty of RnD that went into the design- few revisions. after all, you dont want it to be too big, then it will work against you."
    can you just comment on why it will work against you if it is too big?
    also do you think that if you enlarge the plenum, the throttle body size and bipipe size is not as relevant? since there is an enlarged space to "store" air ... its not as necessary to get the large diameter flow going.
    this topic is heavy in CFD which i wish i knew more about. im going to hit the books and search some other forums.
    what would be REALLY neat is if i could get the dimensions of 2000 s4 intake manifold, 2001.5 intake manifold, rs4 intake manifold, and SPTurks manifold so i could model them up and give it to a coworker for some CFD analysis! then we could get a better idea of whats going on
    1999 Black A4 Avant
    Jan 11 2007
    Salt Lake City, Utah
    Can anyone help him with this? Would be awesome!
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Registered Member Two Rings Knight_Rider's Avatar
    Feb 26 2008
    Go f*ck yourself!
    Quote Originally Posted by jibberjive View Post
    can Anyone Help Him With This? Would Be Awesome!
    Holy Friggin Throwback Batman!
    Somebody Help This Man!
    I am Michael Knight, my car is K.I.T.T.- The Knights Industries Ten Thousand, my organization is F.L.A.G. I am powered by Garrett/Honeywell and GenerationJDM.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    chicagoland
    no intake manifold will yeild 30 whp on a Bseries (N/A)
    NONE..
    closest thing would be ITBs.. but even so.. not 30whp.
    MAYBE 30CHP but thats still not beliveable
    on a kseries. its a little diff story.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Feb 17 2008
    Ottawa Ont.
    Anyone running this manifold, hows it working out?
    Nov 16 2006
    Boston
    hey
    good to see this thread come back from the dead.
    i will have a stock 2001.5 manifold soon, so when i get it ill start messing around with it. i really really want to quantify the gains/changes in airflow / power
    1999 Black A4 Avant
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    what the hell is the is SPTurk mani??? I have never heard of it before......is it a custom mani that SPP does or something???
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    [IMG][/IMG]
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Is there any porting involved with that manifold, or does he just weld a box onto the bottom of it? Its really hard to tell if the runners have been ported from that pic. I can see some gains from that, but if he doesnt do anything to the ports then hes just restricting the extra airflow that he just freed up.
    Any other pics of it?
    2014 Fiat 500 Sport
    Mar 08 2007
    ct
    [IMG][/IMG]
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Feb 14 2004
    Michigan
    NONE..
    I never mentioned naturally aspirated...that manifold is almost always used on a turbo build. Made a world of a difference on my 2.0l, held torque almost all the way to redline
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    I'm not crazy about that expanded manifold... You mentioned a lot of R&D went into it... can you tell us what R&D? Was it flow tested? Running different amounts of air to each cylinder can cause boo boos.
    B7 S4 Avant
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    if someone can give me an assembly in proe or solidworks I can run the CFD through Fluent
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Jan 11 2007
    What does SPturks charge for the mani and are they still being made?
    LOOKING FOR:
    Stage 2 Banner Advertiser Three Rings Dan@JHM's Avatar
    Mar 17 2007
    2007 B7 RS4
    Lathrop
    ive got a spturks manifold for sale btw, pm me if your interested
    Nov 16 2006
    Boston
    Quote Originally Posted by bertworks View Post
    not running it on your GT car? why not?
    what are you gonna run?
    1999 Black A4 Avant
    Mar 17 2007
    2007 B7 RS4
    Lathrop
    right now just stock but in the near future an rs4 setup.
    Nov 16 2006
    Boston
    Quote Originally Posted by RenegadeEngr View Post
    well it wouldnt be an assembly, as it is only 1 part ... but i am working on creating the geometry in pro/engineer now. ill make a stock version, and a couple tweaked versions... are you good with Fluent?
    1999 Black A4 Avant
    Established Member Two Rings Mark@AutoSpeed's Avatar
    Jun 01 2005
    East Coast Pimpin'
    The key with any part that has air flowing through it is to use common sense, pretend you are the air and use smooth transitions. We have been modifying manifolds for a few years now and have seen good results on the GT cars. Have a look at the following pics and observe that to properly reshape the casting areas and remove ALL sharp edges, the bottom of the manifold must be removed. Then you can have full access to clean up the entire area. Without removal of the bottom, your results will be minimal at best.
    Here is the stock manifold, note the casting plate has been removed. I couldn't find any profile shots which shows the abrupt angle change when the air enters the plenum.
    This is a pic that someone posted earlier in this thread...
    There are still many edges that are rough, sharp and gouged. the work done from the pic above does not look very clean and will create unwanted turbulence. Although probably better than stock, but if you are going this far then you should take the time and do it right.
    This is a pic of our ASP design. Note how smooth the bells are around the inlets to each cylinder on our mani vs. the stock and other versions, we don't have any sharp areas as seen in the prior posted pic. Also note we smooth the entire interior, not only the bells, but side walls in between, everywhere. This is important to minimize the areas for turbulence. Also we typically smooth out the inlets and then leave the outlets at the injector port semi rough, never polished as you want some casting grain here to help promote fuel atomization. A super polished exit from the mani will only help fuel pool when cold and cause misfires and carbonization leading to the valves.
    Next we did some calculations and determined we wanted to add approx. a 1" rise in the mid of the plenum. This was a good compromise to give us some extra flow volume while still allowing us to clear the after run pump/plumbing. Note the bottom of our billet scoop has been designed in CAD to determine the smoothest curve to basically allow the air to flow very smoothly, this allows for better acceleration under TIP IN and WOT transitions.
    Hope this help show the main differences of stock vs. modified and help visualize why it works. The 2.7 has all in all a very good quality from the factory, but the manifold casting is just not that good. For creating 250 crank HP its fine, but more than that it needs some love
